engine brake issue
Discussion in 'Volvo Forum' started by waltherz, Jul 26, 2013.
  1. waltherz
    waltherz Light Load Member
    133
    13
    Dec 12, 2012
    i have volvo vn 04 w/ volvo engine 465 and when is parked or stop at traffic light (idling condition) the engine brake try to engage for a few seconds. Sombody can help me what could be ?
    Thanks
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Clutch or brake switch?
  4. waltherz
    133
    13
    Dec 12, 2012
    what do you mean about of the clutch?
  5. snowwy
    snowwy Road Train Member
    20,597
    13,318
    Jul 6, 2009
    being as how the engine brake is designed to come on with the gas pedal off. i don't think there's a clutch or brake switch involved.
  6. waltherz
    133
    13
    Dec 12, 2012
    yes, i thing is something electrical troubleshoot, like pedal gas or a damage wire.
  7. Damage
    Damage Light Load Member
    67
    17
    Jan 13, 2012
    Newark, Nj
    Is the engine cold when it is doing this? The engine brake does turn on to help the engine heat up quicker unless it is turned off in the programing, but as soon as you touch the throttle it turns off. How do you know its coming on? Is it something you are hearing?
  8. waltherz
    133
    13
    Dec 12, 2012
    it does in cold or hot. No message on dash. When start idling the engine brake try to engage and the engine low rpm from 700 to 500 for a few seconds and then release. it does in idling every minute or less.
  9. d281833
    881
    919
    May 15, 2012
    Well if everything was working according to Hoyle I'd agree with you. But there's obviously an electrical issue so what's supposed to be goes out the window.
  10. Damage
    67
    17
    Jan 13, 2012
    Newark, Nj
    We have had some a couple of tractors do that. On ours the tractors idle would drop, then it would blow out a lot of black smoke, and then the epg would shut off and the idle would return to normal. Its hard for me to remember what caused it, but if I am not mistanken we had to put a new egp on it. But I am not certain if it was the EPG itself or the controlller that is mounted to the frameor engine block depending on year. It was a couple years back.
  11. waltherz
    133
    13
    Dec 12, 2012
    Well, the engine brake got activate 3 times and i must pulled over. I disconect the EPG and fixed. I could continue to my deliveries withouth engine brake. I think is this valve is falling.
