Engine chokes/bogs down sometimes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Greggg, Mar 7, 2019.
  1. Greggg
    Greggg Light Load Member
    161
    35
    Jun 30, 2018
    hello,
    Sometimes on my 2005 Detroit S60 on tenth gear my engine chokes/bogs down and goes from 13-14rpm to 10-11.
    I recently installed a full title exhaust manifold, already checked air filter.
    What should I be looking for fuel pump, ecm, injectors, something else ?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    Engines do not run that low. If you are trying to say 1300-1400 down to 1000-1100 then take a moment and type that out. It helps those few of us who have trouble with numbers like me. =)
    In top gear if you got all the way down to 1100, chances are that tractor will be bucking and wanting to stall completely. You would need to shift down at least two gears to recover the proper RPM range to keep it moving.
  4. Greggg
    161
    35
    Jun 30, 2018
    I guess yeah. Still wondering what could be the reasons my engine is doing what it’s doing though and I should be looking for perhaps
  5. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
  6. Marcus t
    Marcus t Bobtail Member
    9
    5
    Nov 12, 2018
    You ever find out what was causing the engine to "bog"? Mine just started doing the same thing.
