engine code reader info needed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by log trucker, Nov 13, 2014.
  1. log trucker
    log trucker Light Load Member
    161
    10
    Dec 19, 2011
    marshfield wi
    I want to know if the newer code readers will read a older 3406c peec 1993 engine or is there a way to make the engine flash codes? It doesn't come up with key on before starting but 30 seconds roughly it flashes engine warning it doesn't seen to store a code though as it has when a sensor has failed. It clears if shut engine off restart and it's gone till about 30 seconds go by again. So is there a good basic code reader that works or what do most of you do? Thanks
  3. snowwy
    snowwy Road Train Member
    20,597
    13,318
    Jul 6, 2009
    you can buy a KR SCANGAUGE. $200. good luck finding the codes on the internet though.
  4. uvulabruzr
    uvulabruzr Bobtail Member
    36
    13
    Nov 1, 2014
    CANADA...EH
    If you come up with a code, I can let you know what it is...cat access!!!
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Here's the PEEC codes I have and I link to a repair manual:
    ftp://84.204.204.67/forum.truck.ru/Engines/3406b_Manual.pdf
    01 Override Of Idle Shutdown Timer
    21 Sensor Supply Voltage Fault
    22 Rack Position Sensor Fault
    23 Timing Position Sensor
    24 Oil Pressure Sensor Fault
    25 Boost Pressure Sensor Fault
    28 Check Throttle Position Sensor Adjust
    31 Loss Of Vehicle Speed Signal
    32 Throttle Position Sensor Fault
    33 Engine RPM Signal Out Of Range
    34 Loss Of Engine RPM Signal
    35 Engine Overspeed Warning
    36 Vehicle Speed Out Of Range
    41 Vehicle Overspeed Warning
    42 Check Sensor Calibration
    43 Rack Solenoid Or Sensor Fault
    44 Timing Solenoid Or Sensor Fault
    45 Shut off Solenoid Fault
    46 Low Oil Pressure Warning
    47 Idle Shutdown Timed Out
    48 Excessive Boost Pressure
    53 ECM Fault
    55 No Detected Faults
    56 System Parameters
    57 Parking Brake Switch Fault
    log trucker and SAR Thank this.
  6. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    That scan gauge where do I get it ? And it will read all codes ? It has to be something that's not a staying because it's not flashing code when key is on flashes 55 system ok it starts fine just after 30 seconds engine lights come on. Still seems to run fine.
  7. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    Has anyone hooked up a scan gauge to this early of a yr truck. ??? Or does anyone know what protocol they used on the early peec engines. Scan gauge tech dept can't say if it will work or not so far. May have to go the Pro link route.
  8. pop's
    pop's Light Load Member
    54
    16
    Feb 3, 2013
    Yulee FL.
    Check out OTC 3418 code reader got mine from advance auto parts for under $ 400.00. It will read & clear engine , abs & more codes.
  9. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    Not to hijack, but does that scanner display datastream as well? I haven't found anything about that on OTC's site.
  10. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    OTC may work but there tech said it won't but there not sure what protocol the programing used on the early peec models 95 and newer should be fine as there was a standard all engine builders used. Mine is a 93 if I knew how those were programed I'm guessing cat used there own protocol not standard. The only tool I know will work is pro link with a specific cat cartridge. I've been unable to get any info from snap on. I guess I don't buy enough tools to get a response from snap on within 24hrs. So still waiting for info from them.
  11. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    It should be J1587. 93 was the last year of the PEEC and you should have a PEEC III, which should have a dedicated J1587 data link connector. If you have a single 40 PIN ECM connector, it's a PEEC III.
    I'm not 100%, but pretty sure. I know the PEEC III was updated to the standard ATA communication protocal.
    log trucker Thanks this.
