Hello everyone,
I am wondering is there a good 9 pin scanner that can read the engine fault codes accurately? Can i use 9 pin to OBD-II wire and then use the OBD-II scanner to read it? I searched on amazon, it seems that the professional ones are very expensive, over 2000 dollars. I am not sure if the more affordable ones which are under 200 dollars are good enough. We have a 2012 freightliner Cascadia with dd15 engine and eaton fuller 13 speed automatic transmission. Thank you!
Engine code scanner
Discussion in 'Trucks [ Eighteen Wheelers ]' started by interested in engine, Feb 17, 2019.
PACLink Wireless Code Reader for Heavy Duty Trucks
I've used this scanner before. Hooks up to your phone. Pretty good for the money. Still miles away from OEM software but it does a decent job of reading codes.SAR, interested in engine and spsauerland Thank this. -
Diesellaptops have good stuff but they aren't cheap, you get anything cheap that works good man
interested in engine Thanks this. -
I just purchased a Launch CR HD scanner for approximately $100 for my Volvo. It's already saved me 2 trips to the shop. It reads and clears codes and so far I'm impressed considering what I paid.
ArminK72 and interested in engine Thank this. -
That's like for the shop, over 6000 dollars
I was looking at that one too, but i saw it has odd-II port, so your Volvo has OBD-II as well? Do you know if i buy a 9 pin to OBD-II wire and be able to make it work? Our truck only has the 9 pin port.
Thank you for the information, I will look into that.
The CR HD version comes with a 9 pin adapter.
