Engine code639:9 on a 2008 International ProStar with Cummins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jktrucker, Sep 10, 2018.
  1. Jktrucker
    Jktrucker Bobtail Member
    4
    Sae 1939 datalink abnormal update rate.communication between ecm and another device on the sae 1939 data link has been lost. What does this code mean?
  3. Jktrucker
    4
    [ATTAC 20180910_131608.jpg H=full]244471[/ATTACH]
  4. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    The code is too generic. You'll need to get an adapter and some software or take it to a shop with those items.
    Is the truck running OK, or is there a problem other than the error message?
  5. Heavyd
    Heavyd Road Train Member
    7,787
    6,225
    Feb 4, 2009
    ECM lost communication with another electronic device such as ABS, body controller or cluster.
    fargonaz and AModelCat Thank this.
  6. Jktrucker
    4
    The truck seems to run fine but the engine warning light is on
  7. mitrucker
    mitrucker Road Train Member
    5,333
    9,643
    Dec 15, 2010
    Lapeer, MI
    Insert dynamite, light, and RUN
  8. Jktrucker
    4
    Is it that bad
  9. mitrucker
    5,333
    9,643
    Dec 15, 2010
    Lapeer, MI
    It’s a Prostar. That one might be worth saving because it has a Cummins in it.
    fargonaz Thanks this.
  10. AModelCat
    160,688
    You've got a datalink/module issue. Basically the engine ECM is having communication issues with another module in the truck.
