Engine codes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by speedoflite2, Oct 4, 2012.
  1. speedoflite2
    speedoflite2 Bobtail Member
    9
    Oct 4, 2012
    I am driving an 05 International 9400I with a Cummins ISX engine. I have 3 fault codes with which 2 I have figured out what it is but the third I can't seem to locate what it is. The first two codes are a 128:f02 PID 131_P and 128:F04 PID131_A Which is erratic or high voltage at tps correct? The third that I cant find is SID 081 136 F05.
    Thanks in advance for the help.
  3. Heavyd
    Heavyd Road Train Member
    7,787
    6,225
    Feb 4, 2009
    The 136 is an ABS address. Is it displayed exactly as you typed it? The LCD display isn't the best at displaying the codes properly and does sometimes display phantom codes that aren't really there. The LCD display should never be used for diagnostics because of this. A proper code reader should be used. A code with an "A" means it is active, "P" is for previously active, or inactive. Do you have a Check engine, or ABS light on?
  4. speedoflite2
    9
    Oct 4, 2012
    No ABs light but my abs kicked in today on wet roads. Possibly threw the code then. I have three lights on the dash concerning engine lights/warning lights. I have stop engine that is red check engine light that is amber and also a warn engine light that is amber. The last one the warn engine light comes on and goes off. Today it was on most of the day. No abs light lit at all and all the lights wok in a self test. Thanks for the reply.
  5. Heavyd
    7,787
    6,225
    Feb 4, 2009
    The codes displayed are also SAE format, not manufacture fault code format. This means the P131 is not engine fault code 131, but SAE fault code 131. You are right, Cummins fault code 131 is for the throttle pedal. This isn't the code you have. Your actual fault code is 2373, or 2374. This is for failed Exhaust back pressure sensor or circuit. The sensor itself is the likely culprit. Sometimes the connector and the terminals can get corroded and cause this code. But this is what is also causing your engine light.
  6. speedoflite2
    9
    Oct 4, 2012
    Where would I find this connector to check and make sure it is not damaged or corroded?
  7. Heavyd
    7,787
    6,225
    Feb 4, 2009
  8. Appotox
    Appotox Bobtail Member
    44
    Apr 6, 2013
    Hey neighbor. Did u ever found out whats that code for that u posted here. A 136:F05, sid081_a.
    I just wonder cause i got it also on my truck , but cannot figure out whata hell is it for. If u did find what is it for or if you find out, would u let me know.
    thanks. If i figure it out in the mean time i'll let u know..
