engine derated
Discussion in 'Freightliner Forum' started by tin714, Apr 21, 2014.
  1. tin714
    tin714 Bobtail Member
    16
    Apr 21, 2014
    I have 2010 Cascadia and 2 yellow check engine light came on and my engine is derated. ECU 128. Can anybody help me..thank
  3. Powder Joints
    7,954
    8,306
    Sep 25, 2007
    Rosamond, SoCal
    ECU 128 is telling you that there is a failure of the engine. There are more numbers than this, to isolate it to specific sensors.
  4. tin714
    16
    Apr 21, 2014
    I had this problem many time lights came on about 1hr30m and came off and I start drive like normal . But when is came on I can't even hit the accelerate pass 1200rpm.
  5. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    blame egr/dpf.
    RedRover Thanks this.
  6. John Miles
    John Miles Medium Load Member
    341
    221
    Nov 14, 2009
    Monroe, NC
    Yeah ... had it happen once to me and a lot of times company wide. The scenario usually starts with the check engine lights coming on and I the info dial says the engine is derated. If it is seriously derated it will only go about 12 mph down the highway ... however ... I have seen and experienced the display stating a derate has occurred and the engine operate normally for a very long time ... like in the order of 6 weeks with the display stating engine derated.
    If it were me, I would drive it ... if you can keep it up to road speed ... and try to get it back to your company shop to let them access the situation. If it will only lug along at 10 to 12 mph there is nothing you can do except to call your company shop and let them tell you what you are to do, which will probably involve a wrecker and tow job. It may be a good idea to call the shop anyway and let them know what it is doing.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    ECU 128 is the module with the code, 128 is the engine. You should be able to hit a botton on the display to toggle to the next screen that gives SID and FMI numbers. If not, you need a laptop to pull the code.
    Both yellow lights coming on is telling me an emmisions related fault, which is vague, but all I can tell you at this point without more info.
  8. tin714
    16
    Apr 21, 2014
    Thank you all!
  9. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    128 could be something relate to fuel...filter. Inject. Harness cups etc at least with my 2007 columbia
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    ECU 128 can be ANYTHING that the engine ECM controls or monitors. The list is pretty big.
    Exiled Thanks this.
  11. IH Truck Guy
    4,722
    54,661
    Mar 2, 2008
    Purgatory
    IIRC,128 is low DEF pump pressure...
