Engine fan air line snapped inside housing
Discussion in 'Ask An Owner Operator' started by RepoweredRookie, Mar 19, 2021.
  1. RepoweredRookie
    RepoweredRookie Light Load Member
    144
    125
    Apr 16, 2019
    Hey guys, got another challenge here. Engine threw a belt and broke Engine Fan Air Line fitting inside fan clutch. My options are drive with fan “On” continuously, or grab a load home and fix it. Anyone know how badly it will hurt my MPG to drive with fan on continuously?
    As always thanks for your responses.
  3. Tug Toy
    Tug Toy Road Train Member
    6,990
    73,218
    Jul 4, 2015
    Corn field
    No problem, just roll with it. I mean obviously you want to get it fixed sooner than later but I bet you won’t notice the difference in fuel?
    RepoweredRookie Thanks this.
  4. RepoweredRookie
    144
    125
    Apr 16, 2019
    Oh great, I really wanted to stay out here with how good the rates are. I appreciate the response and will let know the numbers when I get through a tank. Thank you.
  5. kemosabi49
    10,674
    45,820
    Jan 13, 2013
    SW Arkansas
    When I had my 3406E Cat the Cat dealer told me that the fan took 27 horsepower to run. Bound to use more fuel though how much, I wouldn't know
    jsnell and beastr123 Thank this.
  6. AModelCat
    159,407
    Just grab an easy out and spin it out. Easy peazy.
    Vampire and jsnell Thank this.
  7. RepoweredRookie
    144
    125
    Apr 16, 2019
    Yeah I’m definitely gonna try that, but not much space to work with. But you’re right, I think it can be done, hopefully easier than it looks. TY
  8. RepoweredRookie
    144
    125
    Apr 16, 2019
    27 horse sounds like a lot. We will see, leaving for Georgia to Arizona tomorrow, I’ll post some numbers if anyone is interested.
  9. AModelCat
    159,407
    I've even used the square, tapered part of a round file to extract fittings in areas too tight to fit a regular easy out.
    Flint1 Thanks this.
  10. RepoweredRookie
    144
    125
    Apr 16, 2019
    Interesting, you just gave me an idea. I have a file for a chainsaw chain in my box I could probably jam up in there and twist out. I dunno maybe just buy another cheap easy out set at Lowe’s. I’m gonna try it tomorrow. Thanks for the great idea!
  11. beastr123
    beastr123 Road Train Member
    2,865
    23,511
    Jan 2, 2014
    Moose Jaw SK CAN
    If you have a 1/4" drive extension you may find it will fit backwards on the end of the easyout and you can turn it with a 1/4" wrench or a crescent wrench on the socket end. you can even tap it in with the extension attached
