Engine Fan Staying On...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tkilby, Jun 23, 2010.
  1. tkilby
    tkilby Bobtail Member
    4
    Jun 23, 2010
    05' Pete 379 with a Cat ACERT: The last few day's the engine fan has been staying on 90 % of the time. The air solenoid on the firewall has no power and the manual rocker swich has power only on one side "the yellow/orange wire".
    The Horton clutch seems to be in good working order and will release with air pressure.
    Occasionally the fan does cycle correctly but not often.
    Opinions or suggestions appreciated.
  3. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    is it staying on because you have the a/c on most of the time? if so change the fan switch on top of the rad on a/c line going to condensor, if not try a diff rocker switch, then if that doesnt change it, try a fan solenoid, they are known to stick open. 1 way to check is take air line going into solenoid make sure it is getting air in, then take out line off and see if it is getting air out when you turn key switch to on position. (most times when you turn key on or off you can here the air goin into or exhausting out of the fan clutch, but if you cant here it, then try taking the lines off the solenoid to check)
    tkilby Thanks this.
  4. tkilby
    4
    Jun 23, 2010
    The engine fan will run constantly with A/C on or off. I was thinking the problem was that the fan control solenoid did'nt have electrical power, but was'nt sure why it did'nt...
    Thanks!
    W903B Thanks this.
  5. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    the best thing is take it to the dealer have them hook it up and see why the ecm is holding the fan on. The ecm sends power to the solenoid to shut the fan off. Dont rule out the a/c if the expansion valve gets pluged it will hold pressure for a long time which can keep the fan on.
    tkilby Thanks this.
  6. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    You could have a bad high press switch on the A/C. Thats the swtich that will turn the fan on when the A/C is on and say your not moving to get air flow. Unplug the swtich and put a jumper wire on it and if the fan stops you found your porblem. They can go bad and make the fan stay on even with the A/C off.
    tkilby Thanks this.
  7. tkilby
    4
    Jun 23, 2010
    Jumped the A/C high pres. switch and the fan still runs.....??? may take it to Pete dealer tomorrow.
  8. VARITHMS
    VARITHMS Medium Load Member
    476
    106
    Nov 26, 2009
    HOUSTON
    I had a loose wire on the a/c freon temp relay. I gave it a little tug and it came out. Check all the a/c plugs.
    tkilby Thanks this.
  9. xTHANATOPSISx
    xTHANATOPSISx Light Load Member
    77
    31
    Feb 12, 2010
    Hutchinson, KS
    When my father's Horton fan drive on his '07 started running for no reason, we got it to a shop and it was the fan drive itself that had failed. The bearings were about to dump the fan into the radiator and there was a cone shaped piece of the engagement system that had failed as well causing the fan to stay on all or nearly all the time.
    The fan was rebuilt at that time. The piece that broke was something that the shop at KW never had been observed as failing, so parts had to ship or get stolen from another hub. It's probably not really likely, but its a shot.
    tkilby Thanks this.
  10. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    There are two high pressure switches, one to cut out the compressor and the other to signal the ECM to turn on the fan. Open circuit to the ECM means high pressure, once you jump it to trigger low pressure,(assuming the pressure is faulty), the ECM will count down about 2 to 3 minutes before it will actually turn off the fan. This is to prevent over usage of the fan clutch. All this can be monitored with the computer if you take it in.
    TheBaron97 and tkilby Thank this.
  11. TURKER
    TURKER Medium Load Member
    344
    97
    Aug 11, 2009
    Raleigh NC
    I have 2000 Pete 379 cat 3406 E 475 hp. when I am going up hills with heavy load I am putting on my fan manually to keep engine temp cool .( AC is on or off )is it a good thing to do ? am I demaging anything? Thanks
