engine fan stays on
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wideload, Sep 14, 2012.
  1. wideload
    wideload Heavy Load Member
    868
    388
    Sep 1, 2012
    in the granny lane
    06 KW acert cat
    started a few months ago when i shut truck off at night the next morning the fan would stay on a half hour or hour driving then it would shut off and function properly the rest of the day.
    over the last few months it has gotten gradually worse. taking longer, then if i stoped and idled the truck for a while, then just out of the blue when the fan would come.on pulling a hill then it wouldnt turn off.
    right now it is just on all the time. it hasnt turned off in a week. i noticed the fan solinoid was just replaced when i bought the truck which was a month or so before this started. fuel is killing me with it running all the time, not sure where to.look. does this sound like the fan clutch is gone? is there a way to check it? i was thinking since the solinoid was new this was an existing problem they tried to fix.
    i had a batch of bad solinoids before on another truck but that was the opposit problem. the fan would go off and after a few cycles it would stop coming on.
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    You might have air leaking at the fan hub O-ring that you cannot hear with the engine running. This leakage can vary with change in temp under the hood, possibly leaking when cold and not leaking when under hood temp is warm.
    I would do a key on engine off test with full system air pressure first thing in the morning or when you start your day. Open the hood, turn ignition key to on, check fan hub for releasing and for air leak at fan hub. It may take a few attempts to catch it leaking but more likely to leak with cold engine temp.
  4. -insert name-
    -insert name- ATM squishier
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Might be the fan clutch.
  5. Ryanr
    Ryanr Light Load Member
    71
    14
    Mar 6, 2009
    ontario
    could be the a/c high pressure fan switch,or harness plug that goes to the switch locate the switch,unplug the harness and use a paper clip or copper wire to bypass the switch.just stick the paper clip into both ends of the harness to continue the the power back through the circuit and see if the fan turns off.i went through the same thing a couple years ago and thats what it ended up being,then a month or so ago my fan would come on for 10 min then shut off then come back on for 1 minute,drove me nuts.ended up being the cat coolant temp sensor.the gauge in dash is mechanical so it uses a different sensor.we had to put on computer to figure out since it wasnt showing high temp readings,when we put on computer the voltage at the cat sensor was erratic so i changed all good now.
  6. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    You can apply air to air line going to fan clutch and see if it works. You can also unplug air solinoid while its running and see if it makes noise if it does.then u know the ecm is trying to release fan.
  7. j-bo
    j-bo Bobtail Member
    4
    Also check the plugs on the firewall going up to the solenoid on the firewall. Had trouble out of it being corroded on my peterbilt.
  8. manasteel
    manasteel Light Load Member
    124
    32
    Sep 10, 2012
    the intake manifold temp sensor, located just behind the intake pipe ( two wire sensor ) will also cause the fan to stay on. It can stick in range with a hi temp causing the fan to come on trying to cool the intake temp, and not set a check engine light
  9. Gear head
    532
    91
    Apr 1, 2012
    Belair,md
    Ive also seen loose connection at coolant temp sensor.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    this is correct & makes sense. most probable if I was to just guess.
  11. wideload
    868
    388
    Sep 1, 2012
    in the granny lane
    the fan light on the dash comes on and off and fan stays on. this means its not a sensor or plug. if it was the fan light would be on all the time the fan is on. at least thats my thinking. i did check all the plugs the other night though.
    i got my multimeter out and i have 12v power to one wire so i cut the other wire and connected it directly to chassie ground bypassing the ecm grounding process. the solinoid does not click or cycle at all. i guess its bad even though its fairly new.
