Engine fan won't shut off 99 379 w/ a 60 series
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nextlvl, Feb 7, 2017.
  1. Nextlvl
    Nextlvl Bobtail Member
    17
    Jan 5, 2013
    Any ideas would be helpful. No codes, and I have already checked the obvious...i.e., oil/coolant/and intake temperature sensors, high pressure A/C switch, replaced under dash relay, I have read all posts on this forum related to this, and I am pulling my hair out at this point.
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Bad clutch on the fan sound like if you replaced everything else.
    fargonaz Thanks this.
  4. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    Rebuildable I believe
  5. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Find your fan clutch solenoid, usually on driver side firewall. With air tanks full, key on, engine off disconnect air line going towards clutch you should have air coming out of it. If you do then the clutch itself is stuck. If no air coming out check 2 wire connector on solenoid for 12v+key power on one wire and ground supplied by ECM on other wire. Having both opens your solenoid and allows air to go to fan clutch. Disruption of signals in either of these wires will cause the fan to stay on. On a Detroit it is more than likely the wire from the ECM to the solenoid. It usually breaks close to the connector on the ECM. It is the rear (right) connector on ECM.
  6. Getsinyourblood
    Getsinyourblood Road Train Member
    1,264
    1,769
    Jul 5, 2014
    Retired. North Texas
    You got plenty of freon?
  7. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    Good advise ^^^
    Oxbow Thanks this.
  8. Nextlvl
    17
    Jan 5, 2013
    Negative, brand new horton clutch, functioning correctly. My problem is not in the clutch, fan , solenoid, relay, or manual switch.
  9. Nextlvl
    17
    Jan 5, 2013
    Engine fan light is on, and looking at I/O parameters and dianostic gauges with DDDL software, I cannot see any reason the ecm would be asking it to turn on.
  10. sawmill
    sawmill Road Train Member
    3,598
    66,852
    May 29, 2015
    Evanston, WY
    If it's a 99 it shouldn't be ECM controlled. The fan clutch solenoid is either going to be normally open or normally closed. Depending on that, the switches for coolant temp, A/C pressure and manual fan switch will be the opposite.
    If it's got a Horton coolant temp switch you should double check it. I had to replace mine last year and got a bad one out of the box...apparently there was a bad production run of new switches.
    Oxbow Thanks this.
  11. Nextlvl
    17
    Jan 5, 2013
