engine fault code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jdutton1, Dec 5, 2013.
  1. jdutton1
    jdutton1 Bobtail Member
    32
    I have an 06 Pete 378 with a Cummins isx. It does have the diagnostic switch on dash. Wondering how to manually retrieve codes.
  3. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    Does it have a diagnosic switch under the dash above the clutch pedel. If so turn it on and turn the key on and count 3 digit faults.
  4. jdutton1
    32
    Switch is on left of stereo. Just tried that method and light comes on but don't flash. Light come on yesterday for bout half hour so code should be stored right?
  5. Gear head
    532
    91
    Apr 1, 2012
    Belair,md
    Yes you have to switch it on after key is on or turn it on then put key in on position. Yes it will store fault. Otc sells a nice code reader for about 500. It reads all makes of engine trans.cab module and abs modules.
