Engine fen running non stop
Discussion in 'Volvo Forum' started by chopov78, Jan 14, 2015.
  1. chopov78
    chopov78 Light Load Member
    122
    9
    Feb 27, 2010
    illinois
    ISX 2007,500hp,834000miles.the fen can't stop running.Also have this code/not sure if it's related eith fen/m 128 sid 33 fmi 4,don't have idea what is going on.
  3. Big Don
    Big Don "Old Fart"
    17,996
    35,644
    Sep 8, 2007
    Utah's DIXIE!
    It may very well be related. You need to let your shop know about it.
  4. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    There is an issue with the fan solenoid. Fmi 4 is low voltage or short. Follow the fan airline from fan and you will find solenoid. Without starting the engine turn the key on and you should hear the solenoid click then release when you turn the key off. If it doesn't then either the solenoid is bad or there is a wiring issue going to the solenoid. A test light will help greatly
  5. chopov78
    122
    9
    Feb 27, 2010
    illinois
    This is very helpfull.Thank you.I will try it tomorrow and will let you know.
  6. chopov78
    122
    9
    Feb 27, 2010
    illinois
    Do you know where is that solenoid Im getting nerveus, can not find it.It is a Cummins engine 2007.
  7. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Not sure exactly on cummins but if you trace the air line from the fan hub you should eventually find it
  8. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    located on the cross member behind the cab should be a bank of at least 3. also could be on right frame rail by exhust stack
