Engine fluids red warning light on dash
Discussion in 'Volvo Forum' started by Cecil Graves, Apr 18, 2017.
  1. Cecil Graves
    Cecil Graves Bobtail Member
    I have a 1993 Volvo White/GMC with a cat motor and when I started it yesterday, a red warning light on the dash started buzzing. The light says engine fluids. I have verified good oil pressure and level. Also have verified the coolant level in the reservoir. I have tried bypassing the coolant level sending switch but have same results. Any suggestions?
  3. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    probably bad sensor on coolant level
  4. ramblingman
    ramblingman Road Train Member
    1,152
    1,115
    Jan 12, 2014
    I had a 95 Volvo with a Cat that had this problem. On mine it turned out the nut holding down the coolant sensor terminals on top of the reservoir had come loose and were making intermittent contact. For a long time it only happen when I started it. It gradually got worse and even shut my motor off going down the road a couple times before I figured out what was wrong.
    aussiejosh Thanks this.
  5. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    If bypassing the Coolant level sensor does not kill the light check the oil temp sensor, it is in the pan.
    BUMBACLADWAR Thanks this.
