engine help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by damutt, Jun 30, 2014.
  1. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    ok guys need some help. talked to my company that i just left as a company driver. want to come back as an O/O.
    year they dont care long as i dont want to go to CA (great for me)
    been looking at trucks newest about 98, been seeing alot of Cummins, cat,detroit
    N-14 800-1.6 million decent for longevity?,cheap to overhaul and maintain, fuel milage?
    L-10 700-1.1 million decent for longevity?,cheap to overhaul and maintain,Fuel milage
    S60 11.1 usually topping out at 800k or so
    3406 B and E models 800-1.3 million
    tires i have been seeing lo pro 22.5 gears 3.36-4.10 going to use this for flatp bed western 11
    various wrappers around the truck (KW,Pete,IH,Volvo{heard crap},white, GMC,Ford)
    body dont mean much to me . im not expecting 8 MPG i know it isnt going to happen. just looking for what is going to be easier on the wallet for fuel and maint.
    still have lots of research to do before i buy it cash. truck price is max of 10k. i know i need 10k for emergecny funds.
    so with that info what would you do in my shoes?
  3. 25(2)+2
    18,756
    45,823
    Sep 18, 2006
    the road less travelled
    White and GMC are older versions of Volvo, there are issues. You left out the most numerous make out there, which is Freightliner, and older Western Stars were different, but newer are a division of Daimler(which also makes Freightliner).
    Series 60 12.7 were mostly pre-EGR, there are 11.1s out there but more 12.7s. Up to DDEC IV are non egr. 50 Series is similar but in 4 cylinder.
    Cummins Pre EGR ISX and Signature, N-14 in various builds, later Red Tops(Red painted cast rocker arm covers, started at 460 and went to 525 or thereabouts, non red tops of same vintage topped out at 435, hard parts difference to note there, and before the Red Tops, there were high power and lower power builds, where you needed to read a sticker or decipher a number.
    ISM and m-11 were 11 liters, roughly comparable to the 11.1 Detroit, and L-10 /ISL are 10 liters.
    Mack sold mostly their own unless you were in the extra heavy duty range of the Superliner, then it might be a big Cummins, lots of different Mack engines, but most of what you might be looking at would be the E-6 and E-7 6 cylinder models and I doubt you would see an E-10 V-8.
    The big block Cats were based on the the D-9 engine, and those were shortly named the 3406 series and went through un lettered to the A which I believe was the first direct injected engine, up to the E, which was the first really successful electronically controlled Cat, although there may be some disagreement about either the first, or successful. 3306 was a smaller and lighter engine, and 3176 was smaller still.
    There were later the C- series and later yet, the C without the dash. C-15 and C15
    Lighter weight, would be C-12 and C13.
    I'm running out of time to post this, so leaving the rest for others, to agree or disagree.
    Mooose and damutt Thank this.
  4. damutt
    1,126
    370
    May 6, 2013
    your right i did leave out the Mack motors. were they reliable? and thanks for the info aprrecated
  5. 25(2)+2
    18,756
    45,823
    Sep 18, 2006
    Mack were lighter and shorter time to overhaul historically, the newer ones were probably better in that area. E-7 rating was as high as 460 horsepower.
  6. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Mack engines lacked the power and fuel economy big time, this was before EGR. They had cool sounding jakes though, I'll say that. What company are you working for if you don't mind me asking? You can PM me. DO they have an age requirement on the tractor? Do they pay mileage or percentage?
    I wouldn't own anything other than a Series 60. N14 was a decent motor but the Series 60 got the best fuel, cheaper to maintain and sounded way better. CAT motors, they have their own fan club to, but when I worked at Ryder they didn't quite get the fuel economy and tended to use quite a bit of oil.
  7. damutt
    1,126
    370
    May 6, 2013
    freightliner man years yes have to be CARB compliant. from what they wer saying you can get some out of CA but most of our loads go there.
    PM incoming on employer. all the ttucks we have now are 2008+
  8. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Mack E7 is a good motor as long as that Bosch injection pump is not hanging off the right side which is late 98 and on. Mine got poor mpg's ( 5 ) but the lil gal humped 50 grand down the highway with ease.
    The E7 has a weak oil pump by design...weak as in didn't push enough oil up to the valve train and caused warranty issues. Parts are expensive and proprietary. Many things have to come from Mack and few outsiders stock much for them.
    I would love a B Cat but can't afford it. Wouldn't own a C12 or 13...or a 31 series or a 33 series. My buddies have some issues with the TT C-15.
    I currently own a ISM 425. Good motor, plenty of parts and everybody works on them. Stay out of it and she'll stay in the 6 mpg range. man handle it and it's 5. I own it because it came with the truck, only reason.
    12.7 would be my choice. Good solid gal, plenty of parts and anybody can work on it.
    JMO
  9. damutt
    1,126
    370
    May 6, 2013
    ISM= M11, L10 or n14 sorry still earning Cummins lol
  10. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Actually the earliest cat motor 1693 come out of a scraper or wheel loader. 343D was the industrial version. Early A models were offered both in a DI and precombustion. Earlier cat motors were hit and miss. Had a lot of 1693s blow up but they were used to building a motor that turned 900rpm not 2100. They really nailed it with the B model. Still one of my favorite motors if you know somebody who can play with one. Still to this day one of the only motors you can take from 425 to 515 with 15 minutes, a crescent wrench, and a screwdriver...3 turns on the screw run it down the road long as the pyro don't get above 900 give her 3 more turns set the torque screw and go.
    If you really want her to run find an old timer...that's a little deeper in my bag of tricks than I believe the forum will allow .WWasn't like a cummapart where you had to change buttons in the fuel pumps, and they were and still are cheaper to overhaul than an old 855 don't have to get parts overnighted form Germany either.
    A 9 year old can overhaul a detroit. They're simple basic pull decent fuel milage and they're cheap. Won't make the power of a CAT or a CUMMINS but they're a good running motor. I run yellow motors its a love hate relationship, but then again I've got a Cummins in my pickup and I've cussed that motor more than I've ever cussed one of my cats. To each their own I guess. I've always said only thing a Cummins was good for was hanging on the end of s chain for a boat anchor. I can't stand a bulldog but I'd run an old 500 E9 for I bought a red motor.
  11. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    nothing wrong with a e7 and there a million mile motor cam issues have been fixed by now. 460's are weak unless its a 460p or 460xt there 500hp 427 get you the best torque and fuel mileage. E9's are becoming very rare to run across now few more years you only see them at truck pulls and hear about them in history books
