Engine help
Discussion in 'Freightliner Forum' started by Areies88, Feb 27, 2017.
  1. Areies88
    Areies88 Bobtail Member
    4
    Have a freightliner centry class 05, with Detroit 60 in it. I'm having some issues with truck.
    The truck is spitting out 3 codes I'm trying to fix. Codes are
    Eng High 128s232
    Eng High 128s211
    Eng Open 128s230 05
    Symptoms are the oil pressure and water gauges drop to 0. I lose all fuel to pedal. So I can't move truck.
  3. Areies88
    4
    Eng High 128s232
    Eng High 128s211
    Eng Open 128s230 05
    Symptoms are the oil pressureand water gauges drop to 0. I lose all fuel to pedal. So I can't move truck.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Sounds like a wiring issue to me. SID 232 and 211 are both sensor supplies and showing high voltage. SID 230 is the idle validation in your throttle pedal showing open. I don't have a schematic fro your truck handy, but if they all happen at the same time, I'd trace the wires from the TPS and see if you can find a chaffed spot in a harness where all those things run together. It was pretty common to have wires chaff at the ECM. Pull the plastic covers off the ECM and check out the wires. The ribs on the inside of the plastic covers often rubbed through wires.
  5. Areies88
    4
    Alright I'll take a look. They all happen and same time.
  6. zinita17601
    zinita17601 Road Train Member
    1,318
    1,603
    Aug 19, 2010
    lancaster pa
  7. no love for a trucker
    no love for a trucker Light Load Member
    93
    26
    Jul 28, 2013
    Greensboro, North Carolina
    Yes the throttle body is crazy as well I'll have my low air pressure warning gauge go haywire my fan kick in and all of this occurs when I hit my turn signal I pulled the throttle body cover off and I started wiggling the wires and pushing in the wiring harnesses and everything went back to normal
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Jiggling does not normal make or solve the problem.
    Have a shop look at that bundle and have at it. Bet you some of them are burnt through. No wonder your computer went a little crazy.
    For me and our 2001 century the fault is associated with a specific behavior such as overheating. Not random wild faults which makes sense based on charred wiring.
  9. no love for a trucker
    93
    26
    Jul 28, 2013
    Jiggling it works the wiring harness has a poor connect at time just pushed the wires in to give a secure connection.
  10. Areies88
    4
    Had truck taken in to mechanic, ECM was faulty/bad so had to replace ecm. Thank you everyone for your advice and assistance.
