Engine jump start
Discussion in 'Trucks [ Eighteen Wheelers ]' started by igorkoua, Oct 3, 2014.
  1. igorkoua
    igorkoua Bobtail Member
    42
    8
    Aug 6, 2014
    Anyone tell some good portable jump starter to keep in the truck? Want to be ready for winter, like how many Amps need to start engine in the truck?
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    More than any portable I know of. With a cold engine I'd think you'd be SOL!
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i agree most jump boxes are worthless on a semi, a good set of real heavy duty jumper cables would probably be better.
  5. igorkoua
    42
    8
    Aug 6, 2014
    So more is how much? I seen some portable in range 50-100 amps.. Is 100amps not enough??
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Most trucks have 3 to 4 batteries 800 to 1000 cold cranking amps ... Best winter maintenance is go get batteries load tested replace them if they test bad ... Keep connections clean and a set of jumper cables .. If you pull refeer you have a 53 ft battery charger all you need to do if hooked up is connect positives together truck and trailer are grounded already I have a smaller jump wire I sometimes use to keep batteries up when running bunk heater on a layover
  7. xsetra
    xsetra Road Train Member
    5,096
    6,946
    Aug 21, 2011
    You can jump start your big truck with any vehicle that has a 12 volt system. Hope you never need to.
  8. igorkoua
    42
    8
    Aug 6, 2014
    Thank you!
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    U can start truck from any car, just run car connected to truck batteries about 15 min and truck will start
    Other good idea - just install APU
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I gues I would spend the same amount on 3-4 new batteries, than this unit. but it is nice. If I had one, more than likely I would be using it to get everyone else started, as I buy new batt,/alt starter on a timeline, instead of when they go out, which is always away from home.
