Engine light on ?
Discussion in 'Questions From New Drivers' started by Brandy1410, Nov 18, 2020.
  1. Brandy1410
    Brandy1410 Bobtail Member
    13
    Nov 18, 2020
    I have a question I have a 2012 freightliner Cascadia Cummins ISX motor engine light is on not check engine but engine light no codes running fine can anybody tell me why My engine light can be on
  3. AModelCat
    159,092
    Without a code, its anyone's guess. If its on, there's a fault. You will probably need a computer hooked up to tell you.
    Doealex Thanks this.
  4. Brandy1410
    13
    Nov 18, 2020
    I stoped and there was a service truck I payed to have him hook it up all it told him was my truck was regent to many times I just want to know how to reset the engine light
  5. AModelCat
    159,092
    Too frequent regens is a major problem. You've got issues that need to be addressed.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    give it 24 hours see if it clears on its on
  7. Ironmyke
    Ironmyke Light Load Member
    61
    56
    Jun 18, 2017
    Kansas
    To reset just the engine light next to the seat belt light on the Cummins ISX 15 . (1) Turn off all parasitic loads. (2) Turn engine off , (3) then wait a few minutes for cpu to reset. (4) Next, most important, turn key on to the right one notch , do not start engine, wait until all other system check lights on dash go out ,then immediately cycle key OFF THEN ON 5 more times within 30 seconds from the initial key on.
  8. Ironmyke
    61
    56
    Jun 18, 2017
    Kansas
    You paid him and he never told you what the light was on for? He could have at least give you the SPN number that is causing the engine light to be on. I agree with AmodelCat, the engine shouldn’t regenerate frequently. Is it using too much oil? If it is , this will cause it to regen and eventually knock out your after treatment system.
