I have noticed going through the first five gears when I let off the fuel pedal, I hear something sounds like a Hoot Owl saying Whooo, when I get back on the pedal it goes away?
I have checked my hump hoses and found nothing, any suggestions would be greatly appreciated.
07 T600, Cat c-15 435hp.
Engine making a Hoot Owl Sound???????
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RTR, Feb 14, 2013.
sounds as if you have a leak in your turbo hosing.
'07 C-15 should have compound turbo's (2) check ALL clamps, turbo and plumbing including the convoluted tubing and its clamps, you definitely got yourself a boost leak.
If you can't find anything for a last resort check the exhaust wheels on the turbos. Had a problem with a similar noise after letting off the pedal. The problem was that a couple of the exhaust sleeves broke loose and went through the turbos. The fins on the wheel got tore up causing the noise. Didn't have a boost loss that I could tell just the noise.
No boost leak, turbos checked out fine no air leaks found?????? Any suggestions??
January 25th was my last day with them! Freight got slow, very slow after I turned down 2 hot loads, and decided to move on.
Had one making hoot hoot was a exhaust manifold gasket on the back hole
