Engine oil Temp under 100*F is it nomal ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Reddevil, Apr 20, 2012.
  1. Reddevil
    Reddevil Bobtail Member
    28
    Feb 9, 2012
    Norcross ga
    I'd just installed Teltek Engine oil temp gauge on my 06' Coronado C-15/BXS..i install the temp sensor on the oil pan drain plug..but most of the time its reads under 100*F.only when the outside weather temp is reach to 75*F up then oil will get hot to 124*F.. Is it normal reading temp on CAT engine ? Oh i use Schaffer 7000 syn blend on my engine oil w/Gulf Coast Oil bypass..thanks in advance guy !
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    You have a problem with the gauge installation. Modern engines are oil cooled, the oil temp will be about 10F at least above the coolant temperature.
  4. Reddevil
    28
    Feb 9, 2012
    Norcross ga
    So what is the actual reading John ? 200*F above ?
  5. nicholas_jordan
    nicholas_jordan Medium Load Member
    608
    101
    Mar 31, 2012
    temple texas
    I think you are right, when I first read the OP I thought someone had installed an inline oil-cooler that was working especially well on lightly loaded engine but it seems we have a faulty gauge installation as crankcase oil should run above coolant temp by common sense
  6. Heavyd
    Heavyd Road Train Member
    7,756
    6,195
    Feb 4, 2009
    Is the gauge in Celsius maybe?
    Hardlyevr Thanks this.
  7. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    If the guage accuracy is verified, you might consider checking the oil cooler thermostat and oil cooler bypass operation.
  8. Reddevil
    28
    Feb 9, 2012
    Norcross ga
    Its read 124*F sometimes
  9. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    Don't bet that on every engine...unless I'm using a belly tarp during the winter my oil temp is at least 50' cooler than the coolant temp on a Cat 6NZ.
    rollin coal Thanks this.
  10. Heavyd
    7,756
    6,195
    Feb 4, 2009
    Most of these sensors are the same in the diffs and tranys. Is it possible to maybe swap one out if they have the same plug, or find another one to test out?
