Engine Running and No Coolant Cap (Safe?)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Nov 17, 2018.
  1. PE_T
    PE_T Road Train Member
    I just finished draining the coolant on my truck (2014 Freightliner Cascadia DD15) to repair a coolant hose. I am reading on a repair manual to idle the truck without the “pressure cap.” My guess is they mean without the coolant reservoir cap. Is that correct, or more importantly, safe?
  3. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    The cap prevents your system from building pressure.
    I wouldn't drive my truck far without a cap.
    Probably idle the truck so air pockets will flow out of system.
    MartinFromBC and PE_T Thank this.
  4. Rideandrepair
    17,561
    56,894
    Aug 8, 2015
    That’s after you refill coolant. In order to bleed system of air pockets. Sometimes there Is also a bleeder screw (Petcockinstalled at high point of top hose/ steel tubing to radiator.If so crack it open also till it quits bubbling. Give it 1 or even 2 hrs watching and topping off. It may take up to 1 even 2 more gallons before it’s done.Keep at least a gallon in Truck just in case after you think you’ve got all the air out. First time I learned from having to add almost 2 gallons over 3 hrs or so on My 300 mile trip!! Kept shutting down Lol It can take a long time to get trapped air out be patient 2-3 hrs cap off at idle should do it for sure.
    Crude Truckin', A5¢ and PE_T Thank this.
  5. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Remember to start your APU, if you have one, and also make so to run the heater to get the air out of those as well.
  6. PE_T
    Good point. I didn’t think about my APU.
    Rideandrepair Thanks this.
  7. A5¢
    389
    544
    Oct 30, 2017
    I didn't either when I did my rebuild. I took it for a ride and went into a panic when I saw the reservoir was almost empty! :eek:!
    PE_T, SAR, Rideandrepair and 1 other person Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Radiator cap is everything, pressurizes a normal coolant system. When the cap goes bad and does not adequately work, then you can have a constant series of puzzling overheats.
    Refilling or filling new coolant is a very important time. Hopefully you get it all in eventually with that cap loose.
    It's relatively easier and faster to get the air out of a ordinary V8 engine and radiator than it is to get it out of a big truck. That will take a while.
    Rideandrepair and PE_T Thank this.
  9. Goodysnap
    Goodysnap Road Train Member
    3,772
    9,198
    Jul 12, 2017
    Vacuum filling is the only way to go for filling cooling systems. If you vacuum fill for sure there are no air pockets. Run the engine up to temp and cold fill to the cold full mark after a cold soaking the am. No muss ,no fuss. Any vehicle, any engine.
  10. Rideandrepair
    17,561
    56,894
    Aug 8, 2015
    Please elaborate. Keep cap off I assume let gravity do its work? I’m reminded of gravity bled brakes on cars never done it doesn’t seem like it would even work yet Some Master Techs swear by it.
    PE_T Thanks this.
  11. Goodysnap
    3,772
    9,198
    Jul 12, 2017
    UView | Cooling | Airlift™ Kit
    This is my preferred tool but a quick search will reveal many other choices. Pulls vacuum on the system using venturie effect with compressed air. Pulls coolant into the system once vacuum is achieved. No need to burp or bleed of air while running the engine. Large systems can take 2 draws to fill.
    PE_T, A5¢ and Rideandrepair Thank this.
