engine shaking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by newbie41996, Oct 4, 2013.
  1. newbie41996
    newbie41996 Bobtail Member
    32
    11
    Aug 29, 2013
    dallas tx
    Hey guys I just got put on a different truck
    freightliner
    2007
    622956mi
    and of course it worked fine for awhile but less than a week later, the problems arise.
    This time, at one point in my trip powering up a hill with a 20000 lb load, the engine started making a irregular (pattern) noise, shaking in time with the noise, and loosing and gaining power slightly, check engine light came on, the works. It only did it when going uphill, and eventually I noticed that if I coasted downhill out of gear, the light would come on, which is new to me.
    im parked now, just idling with the cruise control on to prevent the truck from shutting off (cali anti idle) and the engine periodically shakes. If I frog it and hold it up to 1700 rpms, it will gun, hold, make a sound like an electric drill, drop about 200 rpm, stop making that sound, go back to 17 and start over, until I stop frogging and let the petal up, and then the check engine light comes back on for a minute.
    The check engine light comes on only when I'm gassing or just after.
    I'm assuming it's got something to do with my turbo, considering it would be the 3rd truck from this dealer with a turbo problem (don't EVER do business with fussell in dallas)
    Help?
  3. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Change the fuel filter? Is your coolant full?
  4. newbie41996
    32
    11
    Aug 29, 2013
    dallas tx
    New and yes.
    oil pressure normal, water temp stays at 175
  5. little cat 500
    2,048
    1,093
    Jan 17, 2010
    Abbottstown PA
    i wouldnt blame the dealer for the turbo there junk right out of the box what codes do you have now
  6. newbie41996
    32
    11
    Aug 29, 2013
    dallas tx
    Codes
    engine protect light : I I - I I I I I
    check engine light : I I I I I I - I
  7. little cat 500
    2,048
    1,093
    Jan 17, 2010
    Abbottstown PA
    proly a bad injector 61 is injector responce could be wire harness
  8. wilfredbacon15
    wilfredbacon15 Light Load Member
    277
    50
    Sep 29, 2013
    Manila, Philippines
    I'm sure that was also the problem of that engine.
    dude6710 Thanks this.
  9. newbie41996
    32
    11
    Aug 29, 2013
    dallas tx
    Yea injector sounds right its giving me an ecu 128 as well
