Engine shopping What can I put in my 2005 W-900
Discussion in 'Ask An Owner Operator' started by Ericfrancs101, Feb 4, 2024.
  1. Ericfrancs101
    Ericfrancs101 Bobtail Member
    16
    Jun 25, 2023
    Norwood New York
    My engine blew up and I need some help engine shopping. I have a 2005 W-900, it originally had a Cummins in it. The engine that blew thats in it now is a 2004 CAT C15 acert (serial number MXS). What can I put in it that will fit and DOT won’t mess with me? The dealership just keeps saying I cant go backwards, that it has to be at least an 04 and the serial number has to be MXS or NXS. If it had a twin turbo in it than I can’t put a single turbo or a 6NZ. Does the law follow the truck or the engine? If I can’t put anything past an 04 and I don’t what anything after 07 that doesn’t leave a whole big range. Please help!
  3. MRMTRANS
    MRMTRANS Medium Load Member
    363
    390
    Apr 28, 2015
    All I have ever heard is it is illegal to alter the emissions on a truck. I don't know if I'd be worried about law enforcement so much as I would about shops not working on it in case of an emergency. I've never seen or heard of DOT checking emissions except in CA. But every dealership, and some independent shops, I have walked into in recent years has signs posted that will not work on trucks with emissions altered. I can't say that they would indeed follow through with that, or view an engine dropped in the the same as de-rating. I wouldn't want to chance it unless I ran a small region and knew where I could take it beforehand.
    Ericfrancs101 Thanks this.
  4. Long FLD
    Long FLD Road Train Member
    11,894
    48,846
    Mar 4, 2015
    Legally? Emissions have to match what came in it since it’s not a glider. So 04 and newer would be your emission tier.
  5. Ericfrancs101
    16
    Jun 25, 2023
    Norwood New York
    My truck is pre-emissions.
  6. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,384
    Jun 8, 2015
    Pavilion New York
    Acert is an emissions setup. Cat's version of an egr motor if I'm not mistaken.
    Ericfrancs101, drh72 and Bean Jr. Thank this.
  7. FLHT
    FLHT Road Train Member
    1,383
    2,415
    Aug 2, 2014
    You can put any engine you want but not at a dealership.
    Will it meet emissions most likely not.
    Bean Jr. Thanks this.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    Just put another Acert back in that’s your best option
    Stay Puft, W923 and lester Thank this.
  9. 062
    062 Road Train Member
    6,216
    33,464
    Oct 20, 2013
    I’d hate to pay for the labor to swing a motor at a dealership.
    Around here it’s $180ish a hour.
    W923 Thanks this.
  10. Bean Jr.
    Bean Jr. Road Train Member
    5,504
    9,788
    Mar 30, 2014
    EGR is not pre-emissions, it's just not as bad as what came later. DOT technically doesn't get involved in enforcing another alphabet organization's regulations, but it could happen.
  11. AModelCat
    159,124
    Legally speaking you can put any on road engine in there as long as it is not a lower emissions tier than what the chassis left the factory with originally.
    For the sake of simplicity just drop in what came out of it. Swapping to something else is going to complicate things a bit.
