My 1999 VNL64T VED12 will unexpectedly shut down while running down the road. No notice, error codes, just shuts off. It might run for weeks and then this problem occurs.Generally it will restart. Sometimes it will start using the ignition key. Some time the key does nothing, engine wont crank or tlurn over, and I have to jump the starter with a screw driver.
The local Volvo dealer cant find the problem. Probably cause it's running when I take it in for diagnostics. Any chance it could be a faulty ignition switch??
Thanks
Engine shuts off while running down the road
Discussion in 'Volvo Forum' started by gharr8, Sep 26, 2012.
Take a good look at your ignition feed circuit. If it shuts down and then won't crank with the switch, you have lost power feed to the switch. Is the auto reset circuit breaker on the ignition feed circuit heating up?
CondoCruiser Thanks this. -
Also check the little ECM hot wire at the battery. Over time them connection crimps will vibrate to the point of breaking. Yours might be hanging by a thread that you can't see for the insulator boot or corrosion built up under it.
This can be a bad ground in the ignition circuit or bad neutral safety switch.
Start at the neg terminal on your battery(s) and work your way back, look for intermittant resistance readings.
Clean or tighten the ground connection.
Adjust or replace the neutral safety switch. -
check coulant level
Man these volvos are buggy. I'm in a substitute truck while my freightliner is getting worked. On its a Volvo with 130000 thousand miles coming up i83 into pa I'm getting coolant level low and oil level low I'm at a Ryder shop now hoping to get going soon. Oh and the oil and coolant is good.
