engine speed sensor 3406c cat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by log trucker, Aug 9, 2013.
  1. log trucker
    log trucker Light Load Member
    161
    10
    Dec 19, 2011
    marshfield wi
    Looking to change my speed sensor on 3406c peec located on the back of the fuel injection pump. I have the back cover off do I need to take the next section off also or is there a way to pull it out with just the first cover off. Anybody done this that could give me some instructions on this. Thanks in advance.
  3. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    No one has changed one of these ???? Also wanted to know if its possible that the chopper wheel that this sensor reads off could come loose ?? I know these are older engines but someone has had to have worked on these I hope. If I pull the rack control motor out will I be able to see the speed sensor easier ?
  4. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    OK so it looks like I need to pull that second section off to change that sensor. Anyone know if I can pull that and leave the rack position sensor in without affecting it. Also there was oil in the connections is it possible that it could short circuit and cause it to loose the speed signal ?? Seems it would be hard to keep oil out of those plugs as there in oil when engine is running.
  5. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    Nobody has any experience changing one of these. ????? Does anyone know if I pull the second section off back of injection pump with the rack positioning sensor will it throw it off ? I just don't want parts falling out. Looks like with that section off it would be easy to change engine speed sensor. ??
  6. highside
    highside Medium Load Member
    441
    510
    Feb 6, 2010
    Kansas
    Since no one here can help you, I recommend you go to thedieselgarage.com in the heavy duty section. Lots of guys over there with experience in the 3406 A's B's and C's.
  7. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    Already did that no answer there either. It looks easy to pull off I just want to know if its going to mess up the rack sensor.
  8. highside
    441
    510
    Feb 6, 2010
    Kansas
    I couldn't tell you. The only C I ever had was converted to full mechanical.
    Oxbow Thanks this.
  9. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Yes the rack sensor should be recalibrated after you pull the second section of the governor housing off, if you put it together with a new gasket that could be enough to throw it off.
    The reason no one has responded is that they convert to full mechanical instead of chasing these problems that show up with the PEEC, I would suggest that you should start looking for a pump and advance that matches your era of engine.
  10. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    That's what I thought on that rack sensor. SmokinCAT have you heard of any issues with oil getting in the plugs in side there. Both the rack and speed sensor plugs had oil inside the plug. I'm not sure oil would be enough to short out thru plug ??? Very bad design anyway I look at it but it was working just fine after I put a turbo on it last fall till this code for speed sensor signal loss. Maybe I can make a tool to reach thru to the lock nut. Wouldn't be the first time.
  11. 82 international
    82 international Bobtail Member
    Iv got a c model that was converted to mechanical also when i bought it the speedometer and cruise does not work it looks like one plug from the sensor goes to the speed buffer then from there to maybe where the computer crap was any way to get those working again?
