Engine won't fire
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ds1989, Oct 11, 2018.
  1. ds1989
    ds1989 Light Load Member
    54
    38
    Jul 24, 2014
    Kansas City, MO
    82 Freightliner COE 400 Cummins
    Started up like normal, idled low, then died. Haven't been able to start since.
    Just replaced PT pump. Was running like new truck. Checked fuel level changed fuel pump.
    Will start with ether but won't keep running.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    There is a manual screw on the front of the fuel solenoid. Screw it in , I believe , so it will run with no power to it. Check for power to it first. Then if it will not start take the plug out of the side of it and crank the engine. If it is not flowing fuel check for restrictions on the pump supply side. There is a plug on top of the pump, 9/16 wrench ?, If you fill that up with clean fuel it helps new pump start up a lot.
    JohnC123, Rideandrepair and Oxbow Thank this.
  4. ds1989
    54
    38
    Jul 24, 2014
    Kansas City, MO
    Will try that tomorrow....thanks for the info.
  5. ds1989
    54
    38
    Jul 24, 2014
    Kansas City, MO
    Haven't had any luck getting the ole girl started. I'm attaching photo(s) and video to help demonstrate where we are at. Thanks in advance for any input... IMG_0651.jpg IMG_0653.jpg
    VIDEO LINK:
    JohnC123 Thanks this.
  6. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    With your description of how your motor decided to “take a nap”. It sounds like it could be one of 3 things, fuel shut off solenoid (mentioned in above replies), air intrusion in you suction side fuel system, or something has come loose or plugged in you newly overhauled pump.
    First off, check the fuel shutoff solenoid. Thread the thumb nut in on the front side of it. If it starts and runs thread the nut out to shut her off. Fix the solenoid or power to it.
    If that doesn’t get it, start looking for a suction side leak. A loose connector, or wet spot in the fuel line. You truck should be old enough that pulls fuel from the bottom of the tank. If there is a valve on the bottom of the tank. It should be clean on the outside, if it’s wet, it’s leaking. Could pull the line off the bottom and make sure you have good flow. Make sure your fuel filters are tight.
    If she Isn’t running by now, check back in. There’s still more to try
    BoxCarKidd, JohnC123 and ds1989 Thank this.
  7. ds1989
    54
    38
    Jul 24, 2014
    Kansas City, MO
    What do you think, starter or starter solenoid, or both?
    Rideandrepair Thanks this.
  8. ds1989
    54
    38
    Jul 24, 2014
    Kansas City, MO
  9. Rideandrepair
    17,448
    56,618
    Aug 8, 2015
    That’s a picture of the fender. I’ll say both.
    ds1989 Thanks this.
  10. Rideandrepair
    17,448
    56,618
    Aug 8, 2015
    Starter sounds locked up. Does engine bar over? Hit the starter with a Hammer
    lwlevens Thanks this.
