Engineering question...
Discussion in 'Questions From New Drivers' started by Hurrycne, Jun 5, 2009.
  1. Hurrycne
    Hurrycne Bobtail Member
    44
    22
    May 30, 2009
    Goldsboro, NC
    After a thorough search of the newbie forums, I have a question that seems not to have been asked/answered as of yet....
    I will be starting out with TMC # end of the month. Upon receiving my own rig (379, 387, or 388 Pete) at the end of my training/indentured servitude period and actually making it to the house for the first time, this is what I'll be confronted with...
    I have what appears to be a standard concrete-slab driveway w/slight ditch and culvert at the beginning of it, will the driveway be able to handle the weight of the rig, or will it crack up like Humpty-Dumpty bungie-jumping with too long a cord?
    Any guesses, or is it more or less like, "<shrug>, give it a whirl, junebug, an' see what happens!"?
    Thankin any and all in advance for whatever wisdom you may wish to impart. :salute:
  3. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    What's standard?????
    My driveway is 6" thick with reinforcement mat and 4" of 3/4" crushed sub-base....
    Hurrycne Thanks this.
  4. Rat Fink
    Rat Fink Light Load Member
    190
    122
    Nov 18, 2008
    Lethbridge, AB
    I'm no civil engineer but I'll try and adapt what I learned on another form of engineering to this.
    well, take the maximum weight of a set of tandems to be conservative in your calculations. 34,000 pounds.
    The problem lies with the concrete. Do you know if there is any reinforcement? concrete is different from pour to pour as well. If you want to be ultra conservative, look online for bearing strengths of lightweight concrete and assume no reinforcement in the slabs.
    Then, use the good old formula STRESS equals FORCE divided by AREA
    Take the force (34,000 pounds) and divide by the area of the contact patch of the tires. You could even divide 34,000 pounds by 8 to get 4250 pounds per tire and divide that 4250 by the contact patch of one tire.
    So search online to find the average size contact patch of a typical semi tire under full load. (use the area in SQUARE INCHES).
    take 4250 and divide by this area to give you pounds per square inch, or PSI. This is the stress the tires are placing on the concrete.
    next, find the compressive strength. I did a quick search and looks like a lot of average concrete pours fall between 35 and 50 Mpa for strength (MegaPascals which is metric). 1 MPa = roughly 145 Psi.........so 35 Mpa is roughly 5075 PSI for compressive strength.
    The stress you calculate must be under 35Mpa or 5075 psi to be safe.
    Now this is really vague, but should give you somewhat of an idea what you are up against. The stress model I've given assumes the layers under the concrete prevent the slabs from "bending". If there are air pockets under the concrete, or a soft material that will squish under the weight....then the slab will come under a bending force too. The ability of the slab to resist this depends on the thickness, and the strength of the slab.
    Any civil engineers on here? How close do I have this? LOL
  5. 25(2)+2
    18,750
    45,501
    Sep 18, 2006
    the road less travelled
    Tractor only or tractor and trailer? Tractor only, probably, but back it in. Loaded trailer, probably not.
  6. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Driveways are not poured to hold a truck. Most likely you have a 4" slab with WWF as reinforcement ( WWF is the steel you see that is rolled out and has 6" squares). Most of the time they do not use rebar due to cost and there's no need for it. But of course it all depends on where your house is and how they did the work.
    If you can dig down on the side of the slab see how thick the concrete is. 6" just might be ok but you never know what, if any, reinforcement was used. You might look around your housing area and see if anybody pulled up their driveway. Then you could have a pretty good idea what you have.
    You might get away with parking the tractor there but if you have another place that's close I'd go there first until you know for sure what you have.
  7. Hurrycne
    44
    22
    May 30, 2009
    Goldsboro, NC
    Thanks for the repsonses, guys....(altho Rattie kinda made my brain hurt :biggrin_2554:).
    Question was for tractor only, (nowhere near enough room for a trailer, even by itself.)
    As for the concrete itself, have no idea of the composition, it's just the same Norf Cackalackey concrete drive that's all throughout the neighborhood.
    Looks like I'll be diggin through all the papers that came with the house and placin a call to the contractor. (House is 5yrs old, but we've only been here 6mos.)
    (Prolly would'nt hurt to find out if'n I can even park a big truck in here in the first place, huh?)
    If not, I do have a couple of prospects nearby, just tryin to track down the property managers to ask real nice-like.
    Thanks again for the responses, much obliged. :occasion5:
  8. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    Just a tractor probably doesn't weigh a whole lot more at the ground than a car. Remember you're spreading that weight across a larger contact area. 10 tires vs. 4.
    I would regularly park my empty water truck on my standard concrete driveway. Never had a problem.
    When I built my shop I poured a 6" reinforced slab. Now I can park my truck in there full at 46,500 lbs without a problem..
  9. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Tractor only means you are spreading approx 31k lbs over ten tires..should be good for a standard concrete driveway, but your second issue would be the first to check on..and don't forget the neighbors, tey might get quirky...or jealous!
  10. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    That's an awful heavy tractor.. Even with the tank on mine it's only 22K empty..
  11. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    OK, you caught me--glad it was you not the coop! I wasn't awake there..you are right, I was thinking of my MT weight with trailer...21-22k sounds a lot better. Far better on that standard driveway.
    I could have said that weight includes all three of my girlfreinds....ROFL
    Hope the wife or Nana don't read this thread!:biggrin_25512:
    Ken Thanks this.
