Equipment Haulers
Discussion in 'Experienced Truckers' Advice' started by okiedokie, Aug 13, 2011.
  1. okiedokie
    okiedokie Road Train Member
    11,886
    87,116
    Jun 13, 2011
    PNWET
    Here's the question. Do you cover your equipments exhaust if it has a turbo engine when not running for a long distance.
  3. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    Yes. It might damage the turbo if you don't cover the exhaust. I usually wrap the end with duct tape.
  4. RenegadeTrucker
    RenegadeTrucker Road Train Member
    2,754
    2,383
    Dec 25, 2009
    Montana
    Just remember to remove the duct tape before starting the machine, or it can make one hell of a bang!
  5. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    So let's settle it once and for all----what/why do some equipment (for example trucks, farm tractors in particular) have a flapper valve over the exhaust pipe/ why are some pipes curved at a 90 degree bend at the very end. Etc. etc. etc.?
  6. okiedokie
    11,886
    87,116
    Jun 13, 2011
    PNWET
    Keep the rail/moisture out. Ok the other day I helped a guy load a Dozer then tossed him some duct tape. He says what's this for? To cover your exhaust. Couple of other guys were standing around and another one said I've never heard of that. These guys are suppose to be seasoned drivers. One went on about he been around trucking for 20 years blah blah blah. I looked at him after enought BS out of his piehole and said not everyone knows everything bub Thanks for the confirm Gman.
  7. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    No! Equipment sits out in the open in rain, snow, wind and shine and it doesn;t damage the turbo. What's the diffrence if it sits in a windstorm of 60 MPH wind or on a lowbed doing 60 MPH?
    The only way wind would cause a problem is if you had a hole in a piston that allowed the air to flow thru or come thru in the case of a vacuum pressure.
    I have hauled hundreds of piecs of equipment of the years.
    This is just one the loads. Cat 589 Pipelayer stripped of the counterweights and stick. Still grossing ouit at 188,500 lbs.
  8. okiedokie
    11,886
    87,116
    Jun 13, 2011
    PNWET
    A pipelayer? Then what is a flap for?
  9. Prairie Boy
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    The 589 boom tracker doesn't have a flapper.
    Remember that exhausts for the most part have a small hole at the bottom of the elbow that would allow moisture to fall thru.
    If Cat or other equipment operators were concerned they would simply have a flap or other apparatus that would work on the key that would "baffle" the exhaust with the power off or open it up as soon as the power is turned on. Very easy to do with a solenoid if they wanted to.
  10. runningman0661
    5,157
    14,890
    Mar 5, 2009
    Clover, South Carolina
    I pulled new cat equiptment out of there factories for four years they made us either tape or use a small pipe bag to cover the exhaust. It can and has ruined the turbos in the past.
  11. Prairie Boy
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Exactly how does it ruin them? To make the turbo spin, air would have to enter and EXIT. How can it exit without a hole in a piston?
    Rollover the Original Thanks this.
