Ever get the red light on prepass at the but the sign lights up and says to bypass the
Discussion in 'Experienced Truckers' Advice' started by A Bug, Aug 24, 2023.
  1. A Bug
    A Bug Heavy Load Member
    905
    1,818
    Mar 15, 2014
    Sevierville TN
    I was on i40 going by statesville nc and the prepass sensor starts beeping and flashing red so i thought i was going to have to pull in but then the sign on the shoulder lit up saying to bypass so figured let's choose the easier option there. I saved it on my dashcam just in case someone was to chase me down for bypassing but it never happened.
  3. shatteredsquare
    shatteredsquare Road Train Member
    1,403
    1,832
    May 23, 2014
    middle dirt
    F that, i do exactly what my light says, regardless of what scale sign says, trooper pulls you over and you're like "the sign said bypass" and your prepass is up there blinking like "red...red...red...red...red..."
    the prepass keeps blinking for a while afterwards as your alibi if they chase you
  4. TripleSix
    129,822
  5. Big Road Skateboard
    6,194
    34,024
    May 2, 2021
  6. TripleSix
    129,822
    $500 fine if you don’t.
    Big Road Skateboard Thanks this.
  7. 201773
    201773 Medium Load Member
    491
    827
    Dec 14, 2020
    I had the opposite occur at that same scale. My Prepass gave me the green light but the sign said enter the weigh station. What would you do there? I pulled in.
    BillyBobFrank Thanks this.
  8. Moosetek13
    Moosetek13 Road Train Member
    14,680
    18,456
    Nov 1, 2010
    Burnsville, MN
    I've had that happen as well.
    Once I pulled in and parked, went in to ask about it.
    I was told to follow the signal, not the sign. They have it right on their computer screen that I was given the bypass signal.
  9. tscottme
    tscottme Road Train Member
    Nobody will fine you for going into the scalehouse. I've done it both ways.
  10. ISXunlike
    ISXunlike Bobtail Member
    47
    34
    May 12, 2013
    Cortez, CO
    Wait…..you guys go into scales??
  11. shatteredsquare
    1,403
    1,832
    May 23, 2014
    middle dirt
    not on a Monday in Ohio at 0830
