Exactly how big of a deal is rust on my frame...
Discussion in 'Ask An Owner Operator' started by BORNtoROAM, Dec 21, 2013.
  1. BORNtoROAM
    BORNtoROAM Light Load Member
    209
    68
    Jan 23, 2012
    Odessa, TX
    i recently purchased my first truck for a very good price. truck runs great and has a C-15. there is only one problem: visible rust on parts of the frame. i'm thinking/hoping/praying that sanding it down and coating it with like a pickup bed liner material will solve the problem (or at least keep it from getting any worse). i don't think it's TOO bad right now. it's not COVERED in rust. but in a couple spots it worriez me because the rust has started to eat into the metal a bit. but in what i consider the most structurally important part of the frame, it looks okay and doesn't have much or any flaked paint, so i'm hoping that means there isn't rust underneath.
    what do you fellas think... am i in trouble? i drive in dry west texas which is a plus. but once the process has started is there no way to stop it? is it possible/affordable/legal to reinforce troublesome parts of the frame somehow?
    please don't tell me i'm screwed. just hoping i can at least get my money out of the truck, which wouldn't take too long once i get going.
    what do i do :|
  3. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    Post pictures of the rusted areas.
  4. BORNtoROAM
    209
    68
    Jan 23, 2012
    Odessa, TX
    why isn't every frame coated with rhino bed liner from day 1. it's 2013. it should be a law. although my truck is an '07.
  5. BORNtoROAM
    209
    68
    Jan 23, 2012
    Odessa, TX
    i'll get some pics tomorrow in daylight. although i'm nervous to hear your response..
  6. Guardrail
    Guardrail Bobtail Member
    16
    9
    Dec 5, 2010
    Bonner Springs, KS
    Bedliner will not solve your problem. Look into rust converting products like http://www.por15.com/.
    "Hang - Man" and BORNtoROAM Thank this.
  7. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    bedliner products hold moisture in, very bad solution. you can probably have the frame sandblasted and repainted from the cab back for $2000 professionally with high quality epoxy primer and paint. And/or do some or all of the work yourself and save $$$.
    BORNtoROAM Thanks this.
  8. Chinatown
    Chinatown Road Train Member
    73,390
    165,057
    Aug 28, 2011
    Henderson, NV & Orient
    Yes, treat the rust, then paint over it. Several ways to treat rust. Google shows many of them including what Guardrail posted.
    Corroseal is another good method.
    Treat the rust; remove it as best you can, then chemical treat the area.
    Prime the treated area.
    Paint the primed area.
    A chemical treatment to stop the rust is the best, first approach.
  9. BORNtoROAM
    209
    68
    Jan 23, 2012
    Odessa, TX
    glad i asked. i was originally just going to sand it down best i could and spray it down with rustoleum and then paint it to hide my shame. then a friend suggested bedliner would be better and longer lasting and he has a buddy who can do it for me. sounded reasonable so i agreed with him. now i know better.
    guess i won't be needing to post pictures anymore... heh.... problem solved..... heh......
    thanks again everyone
    Chinatown Thanks this.
  10. BORNtoROAM
    209
    68
    Jan 23, 2012
    Odessa, TX
    Cranky Yankee accidentally posted this in my other thread, so figured i'd put it here so others might benefit from the tip as well:
    oh wow ot was already mentioned in this thread. i'm sold
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It's easier if you have a 4" grinder with a wire wheel. When you get done wipe it down good with Acetone and then proceed with the other steps.
