"Excessive axeling"
Discussion in 'Questions From New Drivers' started by RayBlaszak, Mar 5, 2019.
  1. RayBlaszak
    RayBlaszak Light Load Member
    208
    146
    Aug 20, 2015
    Is this really a thing? A couple experienced drivers were saying that in Michigan that if you have the tandems slid all the forward they will write you a ticket because MI has a king pin law that requires the tandems to be in a certain range. What if the only way the load is legal is with them all the way forward? I always thought that you could always do better just not worse but that doesnt seem to be the case. He said his ticket said excessive axeling on it when he received the ticket.
  3. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Never heard of that on the contrary you can get a ticket for having the tandems too far back on certain states. Maybe he lied and had them all the way back?
  4. Ffx95
    1,368
    2,628
    May 18, 2017
    Oh maybe I had a misunderstanding since I just woke up. Let me clarify if your tandems are too far to the rear of the trailer on certain states you can get a ticket. Depends on the state they have their own regulations. I know California is the worst if I recall correctly and don’t quote me it’s 40feet from kingpin to the front axle of the tandems.
  5. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    He telling you the truth, Michigan and Maryland you can get to short with a 53 ! Welcome to the funny farm ,their concerns are tail swing and the bridge laws
    Farmerbob1, 91B20H8, Ffx95 and 4 others Thank this.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    Before March 22, 2018 that was true in Michigan. The law stated on trailers over 50' long, the rear tandem axles had to be between (iirc) 37 and 45 feet from kingpin to center if tandems. The law was changed however and now there is no overhang nor kpra restrictions in Michigan.
    I glide 47, Grumppy and tucker Thank this.
  7. motocross25
    motocross25 Road Train Member
    3,845
    11,664
    Sep 23, 2010
    Overland Park, KS
    If Axl Rose doesn’t start a new band called “Excessive Axeling”, he really screwed up.
    Hatt91, Rollr4872, Joetro and 3 others Thank this.
  8. Flat Earth Trucker
    4,140
    15,537
    Nov 19, 2018
    Your recall ability remains accurate in this instance. If your load is going to California, set your tandems accordingly. Bridge law is strictly enforced in California.
    bzinger Thanks this.
  9. Woodys
    Woodys Heavy Load Member
    774
    1,629
    Mar 16, 2010
    Tampa, FL
    Florida requires you to have your axles forward, too. However in Florida they allow you up to 40k on your axles, so you don't have to worry about your axle weights when you slide your tandems. California wants you axles forward AND they still require 34k maximum on your axles.
  10. Long FLD
    Long FLD Road Train Member
    11,919
    49,077
    Mar 4, 2015
    It’s not a bridge law, it’s a KPRA regulation. Bridge regulations are for weight.
    bryan21384, Bean Jr. and gentleroger Thank this.
  11. MysticHZ
    MysticHZ Road Train Member
    5,882
    5,692
    May 28, 2010
    Back axle, not front axle ... 40ft to the front axle will be illegal.
    Bean Jr., Joetro and Ffx95 Thank this.
  12. Bean Jr.
    Bean Jr. Road Train Member
    5,506
    9,790
    Mar 30, 2014
    Sing it!
