excessive oil leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by trucker48, Feb 10, 2013.
  1. trucker48
    trucker48 Bobtail Member
    12
    Have an oil leak ,thought it was oil pan freightliner said it's a rear structure leak along with pan gasket. saying a 24 hour job. what is the rear structure? couldnt get much of an explaination from them and why a 24 hr job
  3. trucker48
    12
    It's a freightliner century w a detroit 60 series 14l
  4. Paloma
    Paloma Medium Load Member
    650
    233
    May 15, 2012
    Portland, Oregon
    I had an 06 Century with Detroit 60, 14L with 700k miles .. Never leaked or burned 1 drop of oil!
  5. Paloma
    650
    233
    May 15, 2012
    Portland, Oregon
    I have no idea what they mean by a 24 hour job .. Sounds fishy to me.
  6. good for nuthin'
    good for nuthin' Light Load Member
    87
    51
    Dec 8, 2010
    Las Vegas NV
    Ill bet, more than likely they meant the crankshaft seal.I drove a 2001 freightshaker and it would drop oil everywhere I went.We fixed it, but within a year it started all over again.
  7. Nordic Light
    Nordic Light Bobtail Member
    27
    18
    Oct 2, 2012
    Everett, WA
    if its a rear main or crankshaft seal, it is labor intensive near the rear enginge cross member frame rails or they may have had to chase a part. Ask to speak to the shop foreman to pin down parts and labor.
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    We, with oil leaks on our detroits do not like braggers of those who claim No oil leaks! 10 hail mary's & offend NO more! :biggrin_25510: :biggrin_25525:
    spyder7723, jess-juju and Ruthless Thank this.
  9. Jimmbuds
    Jimmbuds Medium Load Member
    398
    179
    Apr 20, 2009
    Daytona Beach, FL
    Yea I have a leak on the back of my detroit also. Had the clutch changed out and while they had the transmission out I told them to replace the rear main seal, well I dont think it was that becasue the truck still leaks, unless they didnt change it, which my paperwork says they did but who knows. Had the pan gasket changed out, wasnt that either. I know some of it is coming from the blow by tube, and I suspect that the seals in my oil cooler are going back becasue I seen oil behind that the other day and it appears it is blowing back on to the bell housing. The only was I seen that was by looking at my coolant filter which was covered in oil. This might be where your issue lies also. Best piece of advice ever dont listen to a thing your dealer says, they will sell you whatever BS they can. Get under there clean the area (brake cleaner works great) up yourself and watch it to determine where the oil is coming from.
  10. Jimmbuds
    398
    179
    Apr 20, 2009
    Daytona Beach, FL
    Also did you ask them for details on this "so called rear structure" leak? I would be asking where it is leaking and what needs to be done to fix the leak. Ask questions and then report back with what they say, it may be true and it may not. Like I said those the biggest thing you can do is get a few cans of brake cleaner and cleaner all the grime and oil off of the engine and bell housing and watch it over the next week or so to see if you can determine where is might be coming from. And it might save you 24 hours of BS labor, the biggest thing I find with truck shops is they give you a solution to your problem but it might NOT CURE your problem. They just suggest something for you to replace and it may or may not fix it, now you just wasted lots of money.
    silver dollar and Paloma Thank this.
  11. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Guys, this same problem whooped the mechanics arse at the job......... on the same truck series / specs. We bought about 10 retired JB condos, Detroit and 10. All '06 . I'm not a mechanic so you have to work with me on the terminology.
    Couple of these had oil leaks, mech thought rear main / pan gasket and lets do clutch anyway so here they go, down for like 3 days... When they cranked them up they still leaked oil ...WTF!!!
    Come to find out there is a cam cover ? Seal ? on the back of the motor that is under the transmission bell housing.....and it commonly leaks. And you have to pull tranny to get it.....
    Jimmbuds Thanks this.
