exhaust smell
Discussion in 'Volvo Forum' started by jpracer1, Jan 1, 2014.
  1. jpracer1
    jpracer1 Medium Load Member
    439
    198
    Nov 26, 2009
    I have exhaust smell coming through the air vents through the heater ac vents,,help any ideas?
  3. jerry123
    jerry123 Light Load Member
    52
    24
    Feb 15, 2011
    Holland, Tx.
    Get under the hood, look for carbon build up, look for smoke & sniff, sniff, sniff...get it fixed. Areas of focus, flex pipe connection bands. exhaust manifold. egr turbos...look over their bolts n seams.
  4. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    Some have a compression brake, and the packings around the shaft go bad, that happens on MBE 4000 that uses that style of engine brake, anyway. They never found the leaks because they were looking at the normal places. I got the brake fixed on one and the leak and hissing noise were gone, too.
    Good luck finding what it is.
  5. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    You don't say if you've done anything to look for a leak or where it's originating from. Have you?
    What I'd do is check first for oil leaking in the engine compartment, possibly onto hot manifold or exhaust parts, as well as checking both by feel and sight around the entire length of your exhaust system, especially at joints/connections. Pay close attention to any flex pipes also.
    Also look for traces of soot and loose clamps, or other signs of a leak.
    With 20 years, I would think you know these basics. I don't know of any "Volvo specific" exhaust problems, other than basic ones mentioned.
    heyns57 Thanks this.
  6. jpracer1
    439
    198
    Nov 26, 2009
    yes I know to look for clamps,leaks and other such common things,what I was looking for is Volvo specific problems
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    there was bulleten about crancase vent hose on D12C engines on conventionals and cabovers. really easy deal to make it longer, becouse sometimes HVAC system sucks smell inside cab, usually when engine goes older and burns oil a bit. Usually I see this problem with '98-02 trucks, generally with conventionals
    Other sourse of smell - exaust manyfold leak and turbo gasket leak. Easy to find poit of leak by black carbone deposits
  8. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    check the top sides of the long Y pipe, mine corroded thru, and it was drawing the fumes back into the cab as you describe,. The rotted spots were not visible just looking from underneath, I had to get my head up to see the top side of the pipe.
  9. Confused
    Confused Light Load Member
    224
    270
    Sep 22, 2009
    somewhere else
    More than likely it's the flex pipe at front of exhaust where it first goes under cab up front. I had same problem, but I never noticed the split because it was where I couldn't get my fat #ss far enough under to see it.
    Not a cheap piece of pipe either.
  10. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    If the OP owns the truck from photo avatar, looks like a Volvo 770; doesn't have the same stupid designed expensive flex pipe from D13;
    I spent lots of $$ on my Volvo D13/2008 fixing exhaust fumes leaks caused by back pressure, DPF regen, EGR; I installed a CO2,carbonmonoxide,smoke detector in my cab ; I replaced the manifold 4 times, once was covered by warranty, after I paid 2000-2400$job; the flex pipe maybe 7-8 times, cracks in DPF housing; joints from EGR and egr cooler; I still have a smoke leak, I feel in my cab and I can't find it; took the truck in 5 Volvo shops they can't figure out where is leaking when the truck is parked; I bought a wireless webcam, I'm going to install it in few different suspected spots and watch on the laptop while the truck is moving pulling harder;
  11. mickey melon
    mickey melon Medium Load Member
    317
    351
    Aug 23, 2013
    Chicago,Il
    KW cajun...............Lets do some physics here.
    Lets say we have a driver whom is brave enough(or crazy enuff) to tackle a mythical stretch of road as your profile picture depicts..
    So lets see.....82% downgrade and 97 miles long....
    Here is what will happen.. If and only IF jhe was able to control the vehicle for the first MILE.........Theres a good chance he will lose control and Flip it over going well over 100 mph and no brakes left.......
    So, He will be laid over on his side, Thinking its all over...NOPE,, The next 96 miles he will be sliding down the hill...Thats over an hour and a half of being on your side going down the hill.. Grab your cameras people.
    No, I did NOT smoke anything prior to this explanation.
    KW Cajun Thanks this.
