Exhaust stack help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mikesuburban1, Jan 14, 2018.
  1. Mikesuburban1
    Mikesuburban1 Bobtail Member
    44
    13
    Dec 30, 2016
    Rockland county ny
    20161214_160538.jpg Soo need to put a taller stack on the truck it' just too #### loud! You will see in the pic the outlet is right near the window so I am going to change out the stack with one thats 12" taller which will be the same height as the back board for the flatbed. Soo should I put a miterd or turnout like I have? Need to get as much exhaust noise out of the cab as possible
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Your choice turn out probably take it up to 13 feet if you are not going to be around any low bridge
  4. Mikesuburban1
    44
    13
    Dec 30, 2016
    Rockland county ny
    From the ground to the head board is 10ft. I do local deliverys so I park on the side of the road under trees so u don' want to put too tall of a stack and it get banged up
  5. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Maybe a different muffler?
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You can mount a shorty muff. under truck to make it easy on ears?
  7. Mikesuburban1
    44
    13
    Dec 30, 2016
    Rockland county ny
    I have a mbrp quite series muffler under the cab. I gonna put a stack thats 12" taller but need to know if miterd or turnout would make a sound level diffrence in the cab
  8. Hanginthere
    Hanginthere Bobtail Member
    43
    38
    Dec 23, 2017
    Turnout will keep the rain out better instead of water getting in the stack
  9. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    A miter cut or flat top cut stack will be quiter then a turn up.
  10. Grainfarmer
    Grainfarmer Bobtail Member
    46
    8
    Apr 25, 2017
    You can buy silencer spools. That might be your best bet. I have flat top on my straight pipe isx and it doesn't help much lol.
  11. MACK E-6
    49,716
    234,718
    What’s a “silencer spool”?
    Oldironfan Thanks this.
