Explain this please ...2013 cascadia vibrations.
Discussion in 'Freightliner Forum' started by bzinger, May 23, 2022.
  1. bzinger
    bzinger Road Train Member
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    Last week I started noticing what I thought was a steer tire vibration on my 80% hankook steer tires that are wearing perfectly and thought time to get them balanced.
    But today before I got a balance done I was in my home shop for a lube it was discovered both front drive axle air bags were leaking and coming apart on the bottom of the bags at the saddle .
    Rear bags were fine so put new front bags on and headed out intending to get the balance work done in a couple days on some down time .
    First I noticed my truck rode better and about 100 miles later it dawned on me no more vibration even at 80 mph which isn't how fast I normally drive lol.
    Can anyone explain this ?
  3. Big Road Skateboard
    6,643
    37,296
    May 2, 2021
    Yes
  4. D.Tibbitt
    152,842
    Might just be the bags were hard and stiff and making it more bumpy.. Idk Just shooting in the dark here.
  5. Short Fuse EOD
    2,786
    8,738
    Jul 29, 2015
    Midwest
    Could your ride height up front not have been to spec with the leak?
  6. austinmike
    124,207
    Only The Shadow knows......
  7. Big Road Skateboard
    6,643
    37,296
    May 2, 2021
    So, driveline angle has much to do with vibration. Have you ever ran with your suspension down?
    If so, that vibration you felt and tranny noises you heard were due to driveline angle.
    And obviously, leaking air bags can affect that if severe.
    Coffey, D.Tibbitt, austinmike and 2 others Thank this.
  8. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    No explaining for you.
    Just an advice.
    Always drive 80 miles an hour.
    You'll feel better.
    Until you get a speeding ticket, of course.
    Just having some innocent fun. LOL.
    You are doing good.
    Cheers.
    merv85, Coffey and bzinger Thank this.
  9. bzinger
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    No I haven't but that certainly makes sence .
  10. beastr123
    beastr123 Road Train Member
    2,916
    23,891
    Jan 2, 2014
    Moose Jaw SK CAN
    sounds like a u-joint angle imbalance that was corrected with the new airbags.
  11. Another Canadian driver
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    Yes, for a short time.
    It damaged the transmission ball bearing after a while.
    It was changed when I overhauled the transmission.
    Not recommended for a long time.
    Lesson learned,
    bzinger Thanks this.
