Extended shaft for Wilson 2000
Discussion in 'CB Radio Forum' started by Knblount, Mar 15, 2016.
  1. Knblount
    Knblount Bobtail Member
    Hi all, I am trying to run a Wilson 2000 on my 2016 Cascadia. Unfortunately, I need a longer lower shaft. I was thinking 22", but I'm having an impossible time finding anything other than the 5" and 10" shafts. Any ideas where I could find a longer one that will work with the Wilson? Or how difficult is it to have one made?
  3. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    I have a custom jig made up for a 3/8 by 24 die to cut threads on - 3/8 inch rod. I can make them any length. Any machine shop can make it for you out of 304 stainless steel.
  4. Knblount
    Any chance you'd be interested in selling one to me?
  5. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    If you show up at my door with a piece of metal I will cut the threads on it for free but I'm not in the business of doing this for a living.
  6. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    If you tell me where you are located I can recommend someone in your area to make it for you but the shipping makes it cost prohibitive to make it worth my time
  7. Diesel Dave
    8,725
    25,016
    Jan 20, 2010
    Hesperia, Ca.
    I'm running the short shaft that came with my original Wilson 1000 I bought 27-28 years ago. My radio works perfectly fine. To my question now, what would I gain if a had a longer shaft made for it besides hitting trees and setting off alarms at the scales for height ?
  8. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    It depends on what type of vehicle it is mounted on and how it is mounted to the vehicle and where the coil is in relationship to the top of your roof. Most likely it would perform better with a longer shaft because I doubt the coil is above your roof if it is on a commercial vehicle.
  9. Diesel Dave
    8,725
    25,016
    Jan 20, 2010
    Hesperia, Ca.
    You see the antenna in my avatar. Probably high the roof on the cab but not the sleeper.
  10. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    Electrically, for peak efficiency,
    NO loading is best.
    Followed by Top loading, center loading, base loading.
    now, mechanically... It is the opposite!
    More efficient = more difficult to deploy. Less efficient = easier to deploy.
    Longer shaft increases the efficiency of the antenna, but might be inconvenient to deploy.
    Diesel Dave and Straight Stacks Thank this.
