Extension cords for wiring in my semi.
Discussion in 'Ask An Owner Operator' started by buddynewOO, Jul 31, 2022.
  1. buddynewOO
    buddynewOO Bobtail Member
    47
    21
    Aug 10, 2020
    MN
    I had a guy tell me I could use heavy duty extension cords instead of buying wire for jobs.
    Any advice on this???
    If you know what gauge of wire should I use for what amp range?
    Thanks,
  3. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    I use extension cords for wiring on the truck. Works great. Extension cord has nice protective covering on it already.
    Size of cord would depend on what you are wiring..
    If its just LED lights they don't draw hardly any amps
  4. xsetra
    xsetra Road Train Member
    5,161
    7,092
    Aug 21, 2011
    I'll second the extension cord. They work great, double insulated and can handle any wattage demand wired for lights.
    Size? I think a 16 gauge cord would be the smallest I would use. 50 footer works great to reach the front terminal box to the back lights of a 48' trailer. Usually cheaper than buying wire from a trailer dealer or parts store. You can use the ends cut off another cord to connect without compromising the longer cord.
    When I bought my "new to me trailer" I put an outdoor rated extension cord from front to rear with wire harness, just in case I would need another wire. Been 4 years and haven't needed it. But I know that rainy, snowy wind blowing night will come.
    I also use extension cords to add circuits in my truck.
    Good luck
  5. AModelCat
    161,302
    Only thing with extension cords is they don't really hold up to exposure to petroleum products as well as automotive wiring does. Don't flex worth a dang either when its cold.
    God prefers Diesels Thanks this.
  6. 77fib77
    77fib77 Road Train Member
    11,306
    73,457
    Jul 7, 2010
    St Louis
    What are you wiring? A fridge? A light? Coffee pot?
    86scotty Thanks this.
  7. Lexuslane
    Lexuslane Medium Load Member
    496
    1,009
    Oct 22, 2021
    Find a wire gauge and Amps chart
    Make sure it’s for 12 volt direct current
    figure out what the amp draw for your device is going to be .
    Add about 59% to that amp number
    then figure out what gauge wire you need , and factor in the distance voltage drop .
    or post it up here and maybe someone will help show you how to figure it out
  8. 86scotty
    86scotty Road Train Member
    4,634
    12,606
    Aug 27, 2017
    Appalachia
    Yep, it would also help to know exactly how the truck is now.
    My truck came with a shore power plug and 3 AC outlets inside. There is standard Romex running behind the walls, from the factory. I wired my inverter through the shore power plug so inverter powers all the outlets and from there I have some short cheapo extension cords. Works fine. When I plug in at home AC power passes through inverter to all AC outlets/cords.
    77fib77 Thanks this.
  9. Ridgeline
    22,609
    120,130
    Just an fyi, you need SJOOW cable, not some cheap extension cord that is not made for weather exposure.
    buddyd157 Thanks this.
  10. skallagrime
    skallagrime Road Train Member
    3,853
    9,925
    Apr 10, 2012
    Indiana
    Thats convienient, ive got a 250 foot spool of 14/3
  11. Ridgeline
    22,609
    120,130
    A spool of what?
    SJOOW?
    cheap extension cable?
