Extreme Range
Discussion in 'CB Radio Forum' started by racemaxx24, Aug 25, 2017.
  1. racemaxx24
    racemaxx24 Heavy Load Member
    718
    922
    Jul 4, 2014
    East TN
    So I don't know much about the inner workings of CBs and such... However I was intrigued today while running on US321 south of Hickory I heard a guy come over the radio advertising "Hightech CB Shop located at I10 and US90" apparently outside Jacksonville FL... I used to hear a woman advertising Finish Line Truck Wash located just west of Nashville while running I80 through Nebraska also.. Are these folks that massive of radios or using repeaters or something to get out that far? I've just got a stock Cobra 29LX on factory antennas so nothing special
  3. rabbiporkchop
    9,682
    6,539
    Feb 9, 2012
    Wapwallopen, Pa
    Skywave - Wikipedia
    Tb0n3 and Crude Truckin' Thank this.
  4. CW Spook
    CW Spook Light Load Member
    No repeaters...you're just hearing skip propagation. As we're at or nearing the bottom of the 11-yr solar cycle, skip happens most frequently during the summer months, and less so, or not at all during the other seasons. At the peak of the cycle (6 or 7 years from now) the band will be open nearly all day, making local communications difficult at best.
    Crude Truckin' and rabbiporkchop Thank this.
  5. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,446
    6,834
    Oct 22, 2016
    North Dakota, Eh?
    Propagation, skip, road noise. Inversions are awesome on VHF. I've talked hundreds of miles using 5 watts on 2 meters. Like @rabbiporkchop said, wiki skywave and you can see how some forms of RF shoot through some layers of the atmosphere, while others are reflected back to the surface of the earth, to be picked up by your transceiver. Some signals might make multiple hops across oceans. I've been around radios for 20 years, and it still fascinates me to this day.
    Blaskowitz Thanks this.
  6. Tb0n3
    Tb0n3 Road Train Member
    4,716
    9,576
    Oct 5, 2012
    Earth
    Additionally, antennas radiate mostly perpendicular so if you lay the antenna flat it'll go up and be more likely to catch skip. Less about power and more about weather conditions.
    Crude Truckin' Thanks this.
  7. rabbiporkchop
    9,682
    6,539
    Feb 9, 2012
    Wapwallopen, Pa
    This is the best I ever did Via ground-wave mobile-to-mobile.
