SUPREMACY AUTO TRANSPORT INC
7865819300
I currently have a 2011 F450 SUPER DUTY and a 3 car kaufman trailer that im looking to put to work. im inbetween applying for carrier authority or seeing if their is any other options leasing on to a company etc. I know getting coverage in florida is quite a task. Let me know if anyone has some options thank you
Attention employers: We now require a valid DOT# for anyone wishing to post a driving position. If your job offer doesn't contain a DOT number, it will not get past moderation and will not appear in the forum. The other requirements in the sticky at the top of this section are still required as well. Thank you for understanding.
f450 dually and 3 car we want to put to work
Discussion in 'Trucking Jobs' started by Ag1988, Apr 16, 2019.
- Thread Status:
- Not open for further replies.
Hi 88 Alpha,
Yes im looking to hire a driver or possibly lease onto a company let me know if im at the correct place, im sorry for the hassle im new to this forum88 Alpha Thanks this. -
Not a problem. It's easy for us to move threads. I apologize for misinterpreting your post. I moved it back to Jobs, since you are trying to hire a driver.
Alpha where would i post also a position for freight brokerage, i appreciate your help
I approved your Freight Brokerage position last night. It is in this same section, just a couple of threads down.
I don't see any reason to combine them, but if it would make it easier for you to keep up with, I can combine that thread and this one for you. -
IF you get a driver i can help loading you up. You can lease into if you have everything else set up.
Reason for edit: Other services offered -
There are quite a few companies up around the Elkhart IN area that would be able to keep you busy and let you run under their authority etc until you figure out what your going to do about getting your own authority. Up around Elkhart you could haul anything from travel pull behind trailers, limos, van conversions, just about anything you could fit on your trailer. Maps might give you at least a starting point so that you can get your equipment at least running and making money. Hope this helps.
- Thread Status:
