Trying to find the air line for a fan clutch 1997 W900L with 12.7 detroit? The piece broke where it comes out of the hose and goes into the hub.
Anyone know the right part to search for?
Thanks in advance.
Pete
Fan clutch air line?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tnpete, May 27, 2017.
It should just be a threaded brass quick disconnect 1/4" air line fitting.
You can always call the KW Stealership and ask them. -
tnpete Thanks this.
Thanks guy's will call KW with the SN Next week. Was hoping I could find the part online.
Pete -
If the airline, go grab some from Napa or where ever. Measure length and install yourself. Plus buy new fittings if the look shabby.
If it's the stem, again go to Napa or some other place. Take broke stem with you to make sure threads and diameter are correct
tnpete Thanks this. -
Thanks for all the info everyone. Sure there will be more coming. Pictures to come soon. 600,000 miles on a 12.7 with 13 speed trans, 24.5 low pro tires, 72" Mid roof sleeper with couch, 1997 W900L. -
Most times its just an NPT thread fitting into the fan clutch housing if I'm remembering it right. I have replaced a couple broken ones on Stars with Detroits. Just have to route the hose so it doesn't rub on the front of the head if you put a short fitting in there I think.
passingthru69 and tnpete Thank this. -
The flex hose from a grease gun is a perfect fit
passingthru69, tnpete and cnsper Thank this. -
And the guy still has not gotten the truck running. He changed out the fuel filter. And has not gotten it back running. And I think he's dumber on working on it then I would be. If it was close to me. I would have it running. But 5 hours or so away. And I'm not running back up there to just try and get it running. I want truck. But I feel if he wants to sell it. He will get someone there to get it running. Engine had 600.000 thousand miles on it. And is everything I want in a truck. But in 19 months. Will turn it into a toy to just pull our RV with. So win Win both ways if I get it. Make money with it and then play in it.
Pete
