Fan clutch sensor 07 c15 379
Discussion in 'Peterbilt Forum' started by 210trucker, Aug 11, 2014.
  1. 210trucker
    210trucker Bobtail Member
    Where would the fan clutch sensor be located on a 2007 pete 379 c15 engine 18 speed be located, fan clutch kicked in hasn't turned off? Also what is the normal temp oil/coolant when running truck with a load being carried not sitting idle?
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    It's controlled by the ECM. You could have an A/C issue, the A/C overrides the fan. Other causes could be a problem in the override switch or wiring, fan hub itself leaking internally. Air releases your fan, so a lack of air, bad fan solenoid, or fan solenoid wiring could also cause it to stay on.
    That's all assuming that the engine is running cool enough not to need the fan on.
