Fan coming on too often
Discussion in 'Ask An Owner Operator' started by maffy95, Jul 5, 2013.
  1. maffy95
    maffy95 Light Load Member
    264
    206
    Oct 20, 2012
    Hey guys I have an issue with the fan coming on at 170 degrees... I recently replaced the condenser for the air conditioner and since then the fan has been coming on way too much...
    any help would be appreciated... is there an adjustment?
  3. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    R U running the air conditioning ?
    that will cause it....
    maffy95 Thanks this.
  4. 123456
    10,555
    5,746
    Oct 22, 2010
    32179
    In this heat mine kicks off and on constantly, at very short intervals.
  5. maffy95
    264
    206
    Oct 20, 2012
    Yes running with AC on....
  6. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Who charged the AC back up?
    If it's too full, fan will cycle more.
    Get a set of gauges on the AC and watch the high pressure reading, for when the fan kicks on.
    Don't just user the goofy gauge you get on a self fill bottle of refrigerant, user the real gauges or take it somewhere that has them.
    If the pressure is right, could be a bad pursue switch.
    Martin
  7. maffy95
    264
    206
    Oct 20, 2012
    Thank you... but what is a pursue switch?
  8. Badcable
    Badcable Medium Load Member
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
    pressure switch*
    There is a low side and high side. If pressure is too low, compressor doesn't run. If too high, same thing.
    Sounds like you're over or undercharged. Put gauges on it.
  9. maffy95
    264
    206
    Oct 20, 2012
    Thank you ... will do....
  10. landstar8891
    landstar8891 Road Train Member
    2,414
    2,310
    Feb 4, 2012
    NY NY
    This is a switch that men have at the Bar room/clubs.Once the Ladies drunk on Tequila,they take there clothes off...
    This switch is internal in every normal healthy hetrosexual man.At that point of the clothes coming off,the ''persue switch'' kicks into high gear..At that point we need the fans to come on often.:biggrin_25521:
    :biggrin_25522:
    Boardhauler Thanks this.
  11. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    System is either over charged or condenser does not have enough cooling capacity for the system.
