Fan drive seals going out
Discussion in 'International Forum' started by demonduck, Mar 18, 2015.
  1. demonduck
    demonduck Light Load Member
    52
    6
    Aug 19, 2014
    You guys working on the Maxxforce 13 2010-2011 been seeing fan drive seals leaking? Our guy without seeing the truck yet believes it not the front crank seal because they haven't seen any of them leak yet, but, have had several fan drive seals leaking? Says neither one is covered under the warrenty. I thought crank seals were covered.
  3. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    There are all sorts of different extended warranties with different levels of coverage. Depends on what you have if those are covered or not. Full engine oil pressure is behind the fan drive seal, so when they leak they usually leak lots. Not a common problem though.
  4. Navisingh
    Navisingh Bobtail Member
    What
  5. jlafume
    jlafume Light Load Member
    241
    324
    Jan 6, 2011
    Victorville,Ca
    Has any one changed out one of these. Is it a big job
  6. Heavyd
    7,773
    6,211
    Feb 4, 2009
    Fan hub drives are a big job, yes.
