Fan rebuild kit 1998 Peterbilt 379
Discussion in 'Peterbilt Forum' started by Cindy, Mar 15, 2019.
  1. Cindy
    Cindy Light Load Member
    73
    5
    Sep 15, 2011
    Lakeland, Fl
    Hi, I have a 1998 Peterbilt 379 3406E cat. I want to rebuild the HORTON HT/S FAN CLUTCH 601158. I don't know which kit to get, the 9500HP or the 9505SP. The fan is not off the truck yet. Is there a way to know which one I need. Thank you
  3. MRMTRANS
    MRMTRANS Medium Load Member
    392
    428
    Apr 28, 2015
    I am guessing you are using Kitmaster rebuild kit? Why not ask whomever you are buying from the difference? When I have rebuilt mine, one kit has bearings and clutch, and the other has clutch only-if I remember right. It was reccomended that I always change the bearings-even if they still feel tight- because they will eventually create more heat and cause o-rings to let air passed them.
    tbot Thanks this.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
  5. Cindy
    73
    5
    Sep 15, 2011
    Lakeland, Fl
    The last six are WN447703.
    Thank you
  6. Cindy
    73
    5
    Sep 15, 2011
    Lakeland, Fl
    Hi MRMTRANS, I did ask and they said it was just the amount of fiction. Which I thought made no sense so that is why I am asking here. Also the 9505SP is 150.00 more then the other one. I did look online somemore and the SP stands for single plate. I guess when I get the part off I might be able to tell more. Thank You for your reply.
  7. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Horton reman is a 791125RMAN. Kitmaster reman is a 91027 or the kit is a 9500HP.
    pushbroom Thanks this.
  8. MRMTRANS
    392
    428
    Apr 28, 2015
    Your welcome.
