Fast Track vs Sidekit
Discussion in 'Flatbed Trucking Forum' started by Clasix1055, Jul 17, 2012.
  1. Clasix1055
    Clasix1055 Even when I'm wrong I'm right
    998
    709
    Jan 26, 2012
    Toledo, Ohio
    So from day one that I tarped a load I decided that I want a Fast Track. (I never said I wasn't extremly lazy). I have now discovered that I can run steel in my area and be home every day off weekends and make just as much if not more than running regional. I am about 3g's shy of my goal to get the Fast Track 2 installed, but I am now having second thoughts that maybe I can save $8,000 and just get a side kit installed for around $4,000 ( I need a bulk head and steel plates for chains put in the floor) Anybody ran both have any suggestions. I know Fast Track is the better of the two options but if I stick to coils and plate should it matter?
  3. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Is buying a different trailer with the fast track and pull up chains already installed an option?
  4. Clasix1055
    998
    709
    Jan 26, 2012
    Toledo, Ohio
    i just purchased this trailer in May so, I guess the short answer is no
  5. Allan M
    Allan M Medium Load Member
    453
    283
    Apr 20, 2009
    A side kit is much lighter than a Fastrak system.
    With a side kit your freight must be less than 8 ft wide and 6 ft tall with a standard kit.
    If you have to side unload with a forklift it's not bad to just take the driver's side off but if you have to unload from both sides it's a pain with a side kit. The Fastrak would be much more versatile for back hauls if you got out of the primary steel producing areas but if you are staying in those areas and your plates are less than 8 ft wide the side kit will work just fine.
    When you say that you need to have "steel plates for chains put in the floor" it sounds like you don't have an aluminum trailer.
    I bought my side kit when I had an aluminum trailer and hauled steel for years but now it sits in storage because my current combination trailer is too heavy with the side kit on for a lot of the steel loads.
    Mind you I have an aluminum headboard, aluminum under belly carrier and extra aluminum posts for hauling bulk produce and that all adds up.
    Clasix1055 Thanks this.
  6. Clasix1055
    998
    709
    Jan 26, 2012
    Toledo, Ohio
    Right now I am 30,000 full of fuel, I would lose the headache rack tarps and thats about it, hmmm I have a combo trl, I really dont want to haul over 48,000 so I guess I have about 2,500 to play with, guess I need to find out what the kit weighs...
    xTHANATOPSISx Thanks this.
  7. Allan M
    453
    283
    Apr 20, 2009
    You are very light and will be fine with either system.
    My side kit with lightweight panels and aluminum headboard probably weighs around 1000 lbs minus the under belly carrier.
  8. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    What kind of steel are you hailing and how is it loaded?? That would help make the decision a little easier.
    Id just go with the sidekit and save your extra $$$. If for some reason it doesn't work like you want or u decide to get another trailer, a sidekit usually sells fast around these parts.
    Also, why do u need a headboard?? I've seen plenty of guys running w/o the headboard and just having HD panels up front. Just keep the headache rack for extra protection. It's no different than running an open flat.
  9. Clasix1055
    998
    709
    Jan 26, 2012
    Toledo, Ohio
    My guy at tarpstop metioned it, I thought it was necessary.... My new passion is coils, fast easy and gets me home, everybody has a sidekit so that shouldnt be an issue. I have to make two trips to Wyoming for a direct customer I think when I get back I will have it put on, I think saving the extra dough is enough of a reason to go with it, I just hope I can stay busy enough
  10. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    There is a guy up here near Gary that has an almost new sidekit for sale. I will grab the flyer when I get home and pass u his info. It was a lightweight kit and pretty cheap.
  11. Clasix1055
    998
    709
    Jan 26, 2012
    Toledo, Ohio
    Thanks ... Then all I have to do is get my floor done and I should be good to go....that would work out well if I can pick that up on my way back in from WY
