Fault code 98
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chad, Apr 9, 2009.
  1. chad
    chad Bobtail Member
    24
    Graham, Texas
    06 pete with a cat motor had this come up twice today can someone tell me what it is?
  3. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Not sure if I remember correct. Maybe someone else can confirm.
    It's what's refered to as a ghost code. We had the same issue with Cat engines when I was with CFI. And I'm wanting to say, it was a 98 code.
    Nothing to be concerned about. Although there may be some additional underlying issues that haven't produced a valid code yet.
  4. coalhauler625
    coalhauler625 Light Load Member
    96
    12
    Jan 6, 2009
    somewhere in VA,KY or WV
    does the engine derate, usually the 90's fault code #'s are acuator codes i think 98 is for the oil press sensor in the rocker-box (just above thermostat housing) my truck had code 98 before but it has been a while and that ACERT piece of $h!t has had several problems
