fault codes
Discussion in 'Freightliner Forum' started by james007, Jan 25, 2015.
  1. james007
    james007 Bobtail Member
    12
    Aug 24, 2014
    when I start truck I get a fault code RSRVC 128s 248 14
    thanks for the help
  3. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    Year, make, model?
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Why is the truck and engine model/year always such a secrete? We cannot help you fix anything when we have no clue what it is.
    128 is the engine. That's the best I can do for you without knowing what engine it is. I can assume that it is a data link fault, which is from memory on a detroit engine in a 2010 Cascadia, but I'm not going to waste my time verifying that until I know that I'm looking for info on the correct truck and engine combo.
    james007 Thanks this.
  5. james007
    12
    Aug 24, 2014
    Freightliner century 2008 D60still having problems with rpm dropping when driving for just a split second can the rpm gage be bad or the dash computer and all the wires and connectors have been looked at. Sorry for the not putting more information about the truck. I have replaced the injectors,fuel pump,rejen system, turbo, ecm, and just about every thing else Thanks for the help
  6. Cascadia
    Cascadia Light Load Member
    86
    43
    Jan 18, 2014
    Were you able to find what the problem was, I'm getting the same code. truck runs fine tho.
