faults due to hurricane sandy
Discussion in 'Volvo Forum' started by VERTICALTRUCKING, Oct 31, 2012.
  1. VERTICALTRUCKING
    VERTICALTRUCKING Bobtail Member
    I need some help trying to figure out some codes. The truck is a 2005 Volvo that got covered in water all the way to the head light!
    MID 128 / PID 94 / FMI 7
    MID 28 / PID 94 / FMI 7
    MID 28 / PID 124 / FMI 5
  3. ladyfire
    ladyfire Light Load Member
    148
    71
    Sep 6, 2010
    Greensboro, NC
    1st fault: "water"
    2nd fault: "water"
    3rd fault: "everywhere"
    ...and not a drop to drink!
    ralph, CondoCruiser and albhb3 Thank this.
  4. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    I can't help you with the fault codes, but I can save you some money, if you haven't done so already, make sure that there is no water leaked in to the rearends, transmission, and engine. If you just crack the drain plugs the water should come out first, if water has entered the cavities. You might also make sure that no water has entered the airbrake system as well.
    CondoCruiser Thanks this.
  5. albhb3
    albhb3 Medium Load Member
    596
    279
    Nov 3, 2009
    would you be willing to say your "sunk"
  6. Taildragon
    723
    449
    Jun 22, 2012
    Indiana
    http://www.heavydutypowertrain.com/md200codes.pdf
    This might help with the fault codes, I didn't know any of the information for your tractor, just click this link.
  7. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    Basically draw a horizontal line at the same height the water got all around the truck. Any electronic module below that line needs to be replaced. Any electrical connection below that line needs to be disconnected, moisture blown out, pack with dielectric grease and reconnect.
  8. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    fuel pressure issues
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    check engine ecm for flood, if sugest water damage remove it, remove cover and let dry.
    But fuel pressure sensor is located on filter unit, so lower the ECM
  10. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    the last time I worked on flood damaged volvos was after disaster flood in Europe. I used to repaer damaged in Chech republic trucks.
    first of all there were many air system components damaged, like EBS modulators, air dryer, rusty calipers.
    Engine ECM is located not so low, but ABS and EBS units are on frame. Frame wiring was wet and there was much sand that damaged wires in a year. so wahs the frame carefully.
    change oil in diffs and take front hubs apart to clear with diesel ore kerosine and regrease.
    really do not delay this deal, as soon you do it you save more
    Disconnect all connectors one by one and use compressed air to clean, put some connector spray (WD40 may be used too) on terminals.
    Taildragon Thanks this.
