Hi there I have a ISX CM870, getting fault code 2359, EGR Diff Pressure sensor ... I saw possible cause for this being a damaged turbo control shutoff valve, and I just installed one of these a few weeks back, also did the exhaust gas pressure sensor a while before that, wondering if I could have a faulty TCSV, or just clogged pressure sensor tubes...
ok so I found the sensor tubes, 3 of em, cleaned em out, one was completely clogged, others very dirty, still got the same fault code, also cleaned the exhaust gas pressure sensor, that was a bit filthy too. do I need to replace the EGR diff. pressure sensor now you figure?
FC 2359 ISX CM870 EGR Diff pressure sensor
Discussion in 'International Forum' started by hd99_fatboy, Aug 21, 2012.
