Fender Bender
Discussion in 'Prime' started by brink, Mar 11, 2013.
  1. brink
    brink Bobtail Member
    31
    Aug 25, 2012
    What if somebody jacknifed thier trailer too much to squeeze out of a nap trap and bent the fairing/wind skirt that is attached to the aft of the cab/sleeper?This was already damaged before when they first got the truck,and was circled on the pick-up inspection form.Now it is slightly more damaged.Nothing real major,it is just bent now.
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    So what if it was damaged before.
    You still screwed up.
    brink Thanks this.
  4. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    your company should have thought about the wheel base before bought the the truck. and if they knew that could happen should have told you about the problem. that being said is also your job to watch for things like that. if there was prior damage maybe they wont notice it. they would be hard pressed to make a big deal out of something that was already damaged.
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    No matter the wheel base you can make contact if you get out of wack far enough.
  6. FozzyNOK
    FozzyNOK Road Train Member
    2,478
    3,820
    Jul 18, 2007
    Oklahomistan
    Stand up and be a man... if its not too late of course
  7. Chinatown
    Chinatown Road Train Member
    77,285
    181,180
    Aug 28, 2011
    Henderson, NV & Orient
    Don't mention it. It was already damaged & noted when you got the truck.
    anj8488, critters and truckon Thank this.
  8. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    No damages to.anything other than your truck. I'd say shut your mouth. Sure, if you want to man up about it, go ahead. However the company will probably hit you with a preventable for something so petty. Now your DAC is trashed over something very simple.
    GOAL next time.
  9. brink
    31
    Aug 25, 2012
    I got caught in the blizzard and was trapped in the fuel bay because trucks in front of me were stuck.I had to jacknife the trailer to get out and slid on the ice.I could have just stayed put till they salted the area but it was just getting worse and I had a window to get out and drive out of the storm.
  10. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,046
    May 13, 2011
    Middle Tennessee
    There ya go. Blame it on the 14 hour clock, the weather and other drivers. Just like our campaigner-in-chief.
    brink Thanks this.
  11. TooGroovy
    TooGroovy Medium Load Member
    407
    99
    Nov 2, 2011
    igetaround
    C
    President Obama is a driver?!!! How much does Harvard charge for a. CDL?
